29400 Discussions
ifort: “line table parameters mismatch. Cannot emit.” What does it mean?
Zaikun
With ifort on macOS, I sometimes encounter “warning: line table parameters mismatch. Cannot emit.” What does this mean? It sounds like an internal warning rather than a warning on my code, is it?
I do not have a small working example for the moment.
Steve_Lionel
Yes, that would be an internal message unrelated to your code. Someone at Intel would need to comment in more detail.
Ron_Green
the "line table" is the internal structure we use in debug builds to associate source line information with blocks of code.  So it sounds like you have -g or -debug options and for some reason or other the compiler is having trouble mapping code back to source lines.  Or source lines + source columns.
What setting do you have for debug?  Is it used consistently across source files during the build?
Are you forcing inlining, or controlling inlining?
Do you have INCLUDE statements in the sources?
I'm trying to find any options or directives related to generating debug information.  That is what the compiler is complaining about - it's not able to properly create the debug object for your code.  It could be for many reasons.
Try
-debug extended
option and see if that helps.
Zaikun
This is what I was using when that warning occurred. It happened only on macOS. Thank you.
ifort -warn errors  -auto -no-heap-arrays -stand f03 -standard-semantics -assume norecursion -u -warn all -debug extended -fimplicit-none -traceback -debug-parameters all -fp-stack-check -O1 -ftrapuv -init=snan,array -fpe0 -fpe-all=0 -assume ieee_fpe_flags -fp-trap=divzero,invalid,overflow -c
The options are as above. All the options are used on all source files.
No, unless it is implied by the abovementioned options.
No.
Ron_Green
one by one, remove and test without
then if it's still failing, replace
-debug extended
with
-g
Zaikun
Thank you @Ron_Green. I will try.
