ifort linker can't find my user libs
Lowell_S_
I've searched the forum for this issue but no luck.
This is my first time trying to link user libs into my source code on linux.
I am NOT using -static or -fast when I compile.
libA.a and libB.a are both archive files I created.
My link statement is,
-L. -l:libA.a -l:libB.a
When I try to compile my program I get the following.
ifort  -L. -llibA.a -llibB.a -o prog.exe
ld: cannot find -llibA.a
Yes, the lib files are located in the same directory as the makefile and source code.
Any suggestions?  Thanks!
Lorri_M_Intel
On Linux, the ld utility takes the argument to the  "-l" switch and prepends the letters "lib" and postfixes either .a or .so until it finds a match.
So, assuming your libraries are literally named "libA.a" and "libB.a", please try this command:
ifort  -L. -lA -lB -o prog.exe
                --Lorri
Steven_L_Intel1
Linux-speak is a bit different. You want:
-L. -lA -lB
TimP
The syntax is of the form
ifort *.f  -lA -lB
If you mean to compile and link all the .f files in the current directory.  It won't work without source and/or object files prior to the -l directives.  As Lorri reminded us, -l implies lib and .a or .so.  I don't know what Makefile fortmat you are using; what you show doesn't look standard.
The form required by the standard linux utility ld, has overwhelming documentation.
https://www.gnu.org/software/binutils/
-L./ is OK if the .a files are in the current working directory, but probably redundant.
Lorri_M_Intel
                --Lorri
Lowell_S_
Thanks for the help. I'm not very knowledgeable on compiling and linking with various systems so sometimes trying to interpret overwhelming documentation can be difficult.
Once I understood the prepend lib and postpend .a characteristics, I got it to work. Lorri's response was the easiest for me to understand.  Thanks, all.
