ifort makefile lapack issue
milenko1976
I am trying to compile a code,I need Lapack libraries.What should I change in FCFLAGS line?Framework is supposed to be
/opt/intel/mkl/lib/ia32 or not?
# Intel iFort Compiler, Mac OS X, using vector library with fast Lapack
# FC90 = f90
# FCFLAGS= -fast -Wl,-framework,vecLib -warn uncalled
# use the line above for vector library with fast Lapack,
# make sure to first uncomment LAPACK sgesv call in Occam.f90
TARGETS= clean Occam2D
OBJSOC= OccamModules.f90 MT2DModules.f90 Occam.f90 MT2D.f90
all: $(TARGETS)
clean:
rm -f *.o *~ core *.mod
rm -f Occam2D
Occam2D:$(OBJSOC)
$(FC90) $(FCFLAGS) -o $@ $(OBJSOC) $(LIBS)
# General compile rules
.SUFFIXES: .f90 .o
.f90.o:
$(FC90) $(FCFLAGS) -c -o $@ $<
Ron_Green
FC90 = ifort
FCFLAGS= -O2 -xhost -warn uncalled
And do you want 32bit or 64bit binaries? For 32, add -m32 to FCFLAGS, else -m64
You'll need to set up a LIBS variable based on your MKL choices. Use their Link Line Advisor to set this correctly.
http://software.intel.com/en-us/articles/intel-mkl-link-line-advisor/
milenko1976
Thanks Ron.32bit so -m32.
milenko1976
Still I have problems:
F95ROOT=/opt/intel/composerxe-2011.1.107
MKLROOT=/opt/intel/composerxe-2011.1.107/mkl
FC90 = $(F95ROOT)/bin/ia32/ifort
FCFLAGS= -O2 -xhost -m32 -warn uncalled
INCLUDE = $(MKLROOT)/include
LD_LIBRARY_PATH = $(MKLROOT)/lib/ia32
CPATH = $(MKLROOT)/include
FPATH = $(MKLROOT)/include
NLSPATH = $(MKLROOT)/lib/ia32/locale/en_US
LIBS=-L$(MKLROOT)/lib/ia32 -lmkl_lapack95 -Wl,--start-group \
$(MKLROOT)/lib/ia32/libmkl_lapack95.a \
$(MKLROOT)/lib/ia32/libmkl_blacs.a \ -Wl, --end group
rm -f Occam2D
/opt/intel/composerxe-2011.1.107/bin/ia32/ifort -O2 -xhost -m32 -warn uncalled -o Occam2D OccamModules.f90 MT2DModules.f90 Occam.f90 MT2D.f90 -L/opt/intel/composerxe-2011.1.107/mkl/lib/ia32 -lmkl_lapack95 -Wl,--start-group /opt/intel/composerxe-2011.1.107/mkl/lib/ia32/libmkl_lapack95.a /opt/intel/composerxe-2011.1.107/mkl/lib/ia32/libmkl_blacs.a \ -Wl, --end group
ifort: error #10236: File not found: ' -Wl,'
ifort: command line warning #10006: ignoring unknown option '-fend'
ifort: error #10236: File not found: 'group'
How to link libraries?
mecej4
change the last LIBS line in the makefile from
to
$(MKLROOT)/lib/ia32/libmkl_blacs.a -Wl,--end group
milenko1976
Well,yes this works but:
/tmp/ifort1CkEJv.o: In function `tofmu_.':
Occam.f90:(.text+0x7270): undefined reference to `sgesv_'
make: *** [Occam2D] Error 1
Don,t know why.
mecej4
Not having seen the source code line(s) containing the call to sgesv(), I cannot be sure, but here are some guesses:
1. You asked twice for libmkl_lapack95.a to be used while linking.
2. You did not ask for the Lapack library (F77) to be included in the link.
Use the Link Line Advisor and transcribe the link line correctly.
The answers given here can become confusing to use since you keep changing the question from post to post within a single thread.
milenko1976
Thanks mecej.I have used link adviser,-I$(F95ROOT)/include/ia32 -mkl=sequential .
It works now.
