29488 Discussions
ifort of oneAPI package generates slower executable
Jon_D
New Contributor II
I am noticing a large slowdown (around 50%) in my code when I compile it with the latest ifort (2021.0.5) distributed as part of oneAPI compared to the Parallel Studio XE version 19.1.3.311. When I perform a hotspots checking with VTune, I see  functions like
_for_ieee_quite_eq_k8_
_for_ieee_signaling_gt_k8
showing up in oneAPI version of the compiler but not in the Parallel Studio XE version. I see that these function are invoked in logical comparisons and they seem to be adding quite a bit of extra overhead which is leading to the 50% slowdown.
Is there any way to turn off or limit the impact of these functions on the code efficiency? Again, they don't show up in pre-oneAPI version of the compiler.
Thanks for any help,
Jon
andrew_4619
I don't see anything interesting in those options so I am out of suggestions. Maybe someone from Intel can comment.
check out standard-semantics some things such as "ieee_compares" stand out.....
Option standard-semantics enables option
fpscomp logicals and the following settings for option
assume: byterecl, failed_images, fpe_summary, ieee_compares, ieee_fpe_flags (if the
fp-model option setting is strict or precise), minus0, nan_compares, noold_inquire_recl, noold_ldout_format, noold_ldout_zero, noold_maxminloc, noold_unit_star, noold_xor, protect_parens, realloc_lhs, recursion, std_intent_in, std_minus0_rounding, std_mod_proc_name, and std_value
andrew_4619
I would suggest posting  or looking at your build options. Various run time checking options can have a big impact. The items you quote look like checks for NANs.
Jon_D
New Contributor II
Here are my build options:
/nologo
/O2
/Qipo
/fpp
/standard-semantics
/Qdiag-disable:5462,8290,10212
/libs:static
/threads
/c
/fp:consistent
/assume:norealloc_lhs
andrew_4619
Jon_D
New Contributor II
standard-semantics build option was indeed the issue. I set /assume: noieee_compares and the program now runs even faster than the one generated with the Parallel Studio XE version of the compiler.
I am curious though: What is the benefit of turning on the ieee_compares flag, given how much overhead it introduces to the program? What does it exactly do?
Jon
andrew_4619
I guess it gives increased quality as errors get flagged rather than  staying hidden and maybe giving bad results. But if your code is bomb proof that safety guard just slows you down....
Steve_Lionel
If one is using the IEEE_ARITHMETIC, etc. modules, the compiler needs to know that it can't take shortcuts or make assumptions about compares, etc. The ieee_compares option is new to me, but I know that in the past it was advised to use /fp:strict when using these modules. I speculate that the options were broken out and then folded into standard-semantics, which makes sense.
