29632 Discussions
ifort preprocessor and variadic macros
Karanta__Antti
Hi!
I was wondering whether ifort's preprocessor supports variadic macros? (see e.g. http://gcc.gnu.org/onlinedocs/cpp/Variadic-Macros.html) If not, are there plans to add such beasts?
::Antti::
No, the Fortran preprocessor is very simple and does not support variadic macros, nor are there plans to add this.
jimdempseyatthecove
You could experiment with shell piping gcc preprocessor in front of (or in place of) fpp.
In your development environment, insert in PATH, in front of other paths, a path to a GCChack folder containing a copy of the GCC preprocessor renamed to FPP.EXE. This assumes the GCC preprocessor can completely preprocess the source. This can also be a shell program youwrite that handles the shell call to GCC then to FPP.
Plan B is to create a batch file that first runs the GCC preprocessor, then runs the FPP preprocessor. Place the batch file into the "hack" folder under the name "FPP.EXE". Windows will (has for me) examine the contents of the start of the file and determine it is a batch file.
Plan C is to create pre-build events and actions to pre-pre-process the files using the GCC pre-processor.
Jim Dempsey
Karanta__Antti
Thanks for the ideas, though I don't think I need the variadic macros so bad I'd be willing to complicate our build like this for them. There are a few things that would have been more convenient if they were available but no big issues.
