29635 Discussions
ifort rejects nested array constructor despite typespec
Harald1
New Contributor II
Intel 2021.5.0 rejects the following code - which is accepted by NAG:
program p
  integer, parameter :: a(*) = [1]
  print *, [ real :: + a  ] ! OK
  print *, [ real :: +[a] ] ! rejected
  print *, [ real :: +[1] ] ! rejected
end
 The compiler gives:
ifort-nested-ctor.f90(4): error #8209: If type specification is omitted, each element in an
array-constructor must have the same type and kind type parameters.
ifort-nested-ctor.f90(5): error #8209: If type specification is omitted, each element in an
compilation aborted for ifort-nested-ctor.f90 (code 1)
Somehow the unary + sign in front of the constructor confuses the compiler.
Harald
Barbara_P_Intel
Thank for reporting this with such a small reproducer. We appreciate that!
I filed a bug report, CMPLRIL0-34589. I'll let you know its progress to a fix.
Barbara_P_Intel
Barbara_P_Intel
This issue with the erroneous error message is fixed in ifx 2023.0.0 and ifort 2021.8.0 that were released in December as part of the oneAPI HPC Toolkit. Please check it out!
Harald1
New Contributor II
Yes, it is indeed fixed.  Thanks!
