I have a complicated Fortran program with multiple modules in many files. When I try to compile with either v14.0 and v15.0 using the -g flag, I segFault on the first line of the program. Removing the -g flag fixes the problem and there are no problems at runtime.
Some sample code is below
program Main implicit none REAL, PARAMETER :: Pi = 3.14159265359 integer,parameter :: ND = 2 real, parameter :: RL = 1.0E-6 !Boundary radius real, parameter :: HN = 5.0E-6 !Length of included needle real, parameter :: HL = 2.0E-6 !Tip height real, parameter :: LTT = 3E-6 !Tip-to-tip distance real, parameter :: RU = 0.5E-6 !Boundary radius real, parameter :: HU = 1.5E-6 !feature height real, parameter :: zLen = HN + HL + LTT + HU real,parameter,dimension(ND) :: Length = (/ 20E-6, zLen /) !computational domain size (r,z) ! Grid Spacing real, parameter, dimension(ND) :: delta = (/ 1.0E-8 , 1.0E-8 /) integer, PARAMETER, dimension(ND) :: cells = Length / delta real,parameter :: VApplied = -150 REAL, PARAMETER :: cathode_temperature = 1473.14 !Cathode TemperatureREAL, parameter :: anode_temperature = 973.14 !Anode Temperature real :: Cathode_Voltage, Anode_Voltage REAL, dimension(0:cells(1), 0:cells(2)) :: phi REAL, dimension(0:cells(1), 0:cells(2)) :: temperature !grid-wise gas temperature integer:: i,j phi = 0.0 temperature = 0.0 Cathode_Voltage = VApplied Anode_Voltage = 0 forall(i=0:Cells(1), j=0:Cells(2), j <= nint(lowerBoundary(i * delta(1)) / delta(2))) phi(i,j) = Cathode_Voltage temperature(i,j) = cathode_temperature end forall forall(i=0:Cells(1), j=0:Cells(2), j >= nint(upperBoundary(i * delta(1)) / delta(2))) phi(i,j) = Anode_Voltage temperature(i,j) = anode_temperature end forall !forall(i=0:Cells(1), j=0:Cells(2), (j > nint(lowerBoundary(i * delta(1)) / delta(2))) .and. (j < nint(upperBoundary(i * delta(1)) / delta(2)))) ! phi(i,j) = Cathode_Voltage + (Anode_Voltage - Cathode_Voltage) * ((delta(2) * j - lowerBoundary(i * delta(1)) ) / ( upperBoundary(i * delta(1)) - lowerBoundary(i * delta(1)) )) ! temperature(i,j) = cathode_temperature + (anode_temperature - cathode_temperature) * ((delta(2) * j - lowerBoundary(i * delta(1)) ) / ( upperBoundary(i * delta(1)) - lowerBoundary(i * delta(1)) )) !end forall contains pure function LowerRegion(r) result(k) implicit none real,intent(in) :: r integer :: k if (r < 0) then k = 0 elseif (r < RL) then k = 1 elseif (r >= RL) then k = 2 elseif (r > R) then k = 3 endif end function LowerRegion pure function UpperRegion(r) result(k) implicit none real,intent(in) :: r integer :: k if (r < 0) then k = 0 elseif (r < RU) then k = 1 elseif (r >= RU) then k = 2 elseif (r > R) then k = 3 endif end function UpperRegion !!!!!!!!!!!! Define geometry for regions radially !!!!!!!!!!!!!!!!!! pure function lowerBoundary(r) result(z) implicit none real,intent(in) :: r real :: z if (LowerRegion(r) == 1) then z = HN + HL * (1.0 - (r / RL)) elseif (LowerRegion(r) == 2) then z = 0.0 endif !end function lowerBoundary_Scalar end function lowerBoundary pure function upperBoundary(r) result(z) implicit none real,intent(in) :: r real :: z if (UpperRegion(r) == 1) then z = zLen - HU * (1.0 - (r / RU)) elseif (UpperRegion(r) == 2) then z = zLen end if end function upperBoundary end program Main
This actually appears related to the opt-level -O0 which is implied by -g. The seg-fault is reproducible with just -O0. I will look into this further and report it to development for a deeper investigation and let you know what we find.
If you are needing to debug your larger app, the seg-fault can avoided using with -O1, and if needed you can throw additional options: -debug, -traceback, -g, etc.
(Internal tracking id: DPD200376283)
There are probably thousands of instances where there is no problem compiling with -g, in contrast to your single case of seeing a seg-fault. It is only if you post details of the circumstances and, possibly, the sample code, that there will be grounds for investigating and fixing the problem.
[P.S.: When I wrote this comment, #1 had no code at all. The O.P. edited his post and added the code later.]
Switching to the -O1 optimization fixes the SegFault issue but it makes it so that my debugging program (Allinea DDT 4.2) does not advance linearly. Is there any other possible fixes?
Sorry. I tried a number of different things and I cannot find anything. The issue appears related to the FORALL. Only one is required to be present/active to cause the seg-fault. I will ask for Development's help in finding a possible work around.
Development found an underlying stack issue at -O0 and that the seg-fault occurs related to stack temps created for the FORALL statements. There are two other workarounds.
Workaround #1 is to increase stack size limit. I was successful with your test case using: ulimit -s unlimited
Workaround #2 is to use DO loops instead of FORALL, as follows:
do i=0,cells(1) do j=0,cells(2) if (j <= nint(lowerBoundary(i * delta(1)) / delta(2))) then phi(i,j) = Cathode_Voltage temperature(i,j) = cathode_temperature endif if (j >= nint(upperBoundary(i * delta(1)) / delta(2))) then phi(i,j) = Anode_Voltage temperature(i,j) = anode_temperature endif end do end do
I will update again when I know more.
