29278 Discussions
[ifort v12.0]error #8314:If the rightmost part-name is of abstract type, data-ref sha ll be polymorphic
Dharma
Can some one help me fix the error with this code. I have seen this error in a couple of other threads but they were for earliler compilers verions. I have tried compiling the code using ifort v12.0.
[bash]! Code Source : http://portal.acm.org/citation.cfm?id=1644004&picked=formats&CFID=111758759&CFTOKEN=88505529
! Paper Title : Design patterns for multiphysics modeling in Fortran 2003 and C++
! Journal     : ACM TOMS, Volume 37 Issue 1, January 2010
module integrable_model_module
 implicit none ! Prevent implicit typing
 private ! Hide everything by default
 public :: integrate ! expose time integration procedure
! This stateless type specifies the operators required to support Runge-Kutta time integration,
! while deferring the actual implementation of those operators to extensions (children) of this type.
 type , abstract ,public :: integrable_model
  contains
  procedure(time_derivative ) ,deferred :: d_dt ! time derivative
  procedure( symmetric_operator ) ,deferred :: add ! add two integrable_model objects
  procedure( symmetric_assignment) ,deferred :: assign ! assign one integrable_model to another
  procedure(asymmetric_operator ) ,deferred :: multiply ! multiply an integrable_model by a real scalar
  generic :: operator(+) => add
  generic :: operator(*) => multiply
  generic :: assignment(=) => assign
 end type integrable_model
 abstract interface
  function time_derivative(this) result(dState_dt)
   import :: integrable_model
   class(integrable_model) ,intent(in) :: this
   class(integrable_model) ,allocatable :: dState_dt
  end function time_derivative
  function symmetric_operator(lhs,rhs) result(operator_result)
   class(integrable_model) ,intent(in) :: lhs,rhs
   class(integrable_model) ,allocatable :: operator_result
  end function symmetric_operator
  function asymmetric_operator(lhs,rhs) result(operator_result)
   real ,intent(in) :: rhs
  end function asymmetric_operator
  subroutine symmetric_assignment(lhs,rhs)
   class(integrable_model) ,intent(in) :: rhs
   class(integrable_model) ,intent(inout) :: lhs
  end subroutine symmetric_assignment
 end interface
 contains
  subroutine integrate(model,dt) ! Explicit Euler time integration
   class(integrable_model) :: model
   real ,intent(in) :: dt ! time step size (integration interval)
   model = model + d_dt(model)*dt ! Explicit Euler formula
   contains
    function d_dt(this) result(dThis_dt) ! support d_dt(arg) time differentiation syntax
     class(integrable_model) ,allocatable :: dThis_dt
     allocate(dThis_dt,source=this)
     dThis_dt = this%d_dt()
    end function
  end subroutine
end module integrable_model_module
! Command used for compilation
! ifort -c integrable_model.F90
!--Error Mesage on compilation
!error #8314: If the rightmost part-name is of abstract type, dat
!a-ref shall be polymorphic   [D_DT]
!     dThis_dt = this%d_dt()
!compilation aborted for integrable_model.F90 (code 1)
!--Compiler Info
! ifort (IFORT) 12.0.0 20101006
! Copyright (C) 1985-2010 Intel Corporation.  All rights reserved.
[/bash]
Steven_L_Intel1
integrable_model is an abstract type. The language doesn't allow you to use such types directly - you can only extend them. This particular usage, where you try to call a type-bound procedure of an abstract type, has been discussed among the Fortran standards committee and they agreed that such a use was not legal.
Dharma
I Have simplified the code and implemented another module, in which the abstract type is extended. I am not sure if i did this correctly. I still got that error message. Can you please check this?.
[fortran]module integrable_model_module
  contains
 abstract interface
 end interface
module integrable_model_extended_module
 use integrable_model_module
! private ! Hide everything by default
! public :: integrate ! expose time integration procedure
type , extends(integrable_model) ,public :: integrable_model_extended
  contains
  procedure :: d_dt=>time_derivative_ex ! time derivative
  procedure :: assign=>symmetric_assignment_ex ! assign one integrable_model to another
 end type integrable_model_extended
  contains
 ! there will be a warning, ignore it
  function time_derivative_ex(this) result(dState_dt)
   class(integrable_model_extended) ,intent(in) :: this
  end function time_derivative_ex
  subroutine symmetric_assignment_ex(lhs,rhs)
   class(integrable_model_extended) ,intent(inout) :: lhs
  end subroutine symmetric_assignment_ex
   class(integrable_model_extended) :: model
   model =  d_dt(model) ! Explicit Euler formula
   contains
    end function
  end subroutine
end module integrable_model_extended_module[/fortran]
Steven_L_Intel1
A follow-up to this - after more research and discussion, we decided that this usage is legal and the compiler will be fixed in an update later this year.
Dharma
Thank you. What is the expcted relase date for the next update ?
Steven_L_Intel1
If you mean the update that includes the fix for this, I believe it is currently scheduled for sometime in October.
