Can some one help me fix the error with this code. I have seen this error in a couple of other threads but they were for earliler compilers verions. I have tried compiling the code using ifort v12.0.
[bash]! Code Source : http://portal.acm.org/citation.cfm?id=1644004&picked=formats&CFID=111758759&CFTOKEN=88505529
! Paper Title : Design patterns for multiphysics modeling in Fortran 2003 and C++
! Journal : ACM TOMS, Volume 37 Issue 1, January 2010
module integrable_model_module
implicit none ! Prevent implicit typing
private ! Hide everything by default
public :: integrate ! expose time integration procedure
! This stateless type specifies the operators required to support Runge-Kutta time integration,
! while deferring the actual implementation of those operators to extensions (children) of this type.
type , abstract ,public :: integrable_model
contains
procedure(time_derivative ) ,deferred :: d_dt ! time derivative
procedure( symmetric_operator ) ,deferred :: add ! add two integrable_model objects
procedure( symmetric_assignment) ,deferred :: assign ! assign one integrable_model to another
procedure(asymmetric_operator ) ,deferred :: multiply ! multiply an integrable_model by a real scalar
generic :: operator(+) => add
generic :: operator(*) => multiply
generic :: assignment(=) => assign
end type integrable_model
abstract interface
function time_derivative(this) result(dState_dt)
import :: integrable_model
class(integrable_model) ,intent(in) :: this
class(integrable_model) ,allocatable :: dState_dt
end function time_derivative
function symmetric_operator(lhs,rhs) result(operator_result)
class(integrable_model) ,intent(in) :: lhs,rhs
class(integrable_model) ,allocatable :: operator_result
end function symmetric_operator
function asymmetric_operator(lhs,rhs) result(operator_result)
real ,intent(in) :: rhs
end function asymmetric_operator
subroutine symmetric_assignment(lhs,rhs)
class(integrable_model) ,intent(in) :: rhs
class(integrable_model) ,intent(inout) :: lhs
end subroutine symmetric_assignment
end interface
contains
subroutine integrate(model,dt) ! Explicit Euler time integration
class(integrable_model) :: model
real ,intent(in) :: dt ! time step size (integration interval)
model = model + d_dt(model)*dt ! Explicit Euler formula
contains
function d_dt(this) result(dThis_dt) ! support d_dt(arg) time differentiation syntax
class(integrable_model) ,allocatable :: dThis_dt
allocate(dThis_dt,source=this)
dThis_dt = this%d_dt()
end function
end subroutine
end module integrable_model_module
! Command used for compilation
! ifort -c integrable_model.F90
!--Error Mesage on compilation
!error #8314: If the rightmost part-name is of abstract type, dat
!a-ref shall be polymorphic [D_DT]
! dThis_dt = this%d_dt()
!compilation aborted for integrable_model.F90 (code 1)
!--Compiler Info
! ifort (IFORT) 12.0.0 20101006
! Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
[/bash]
integrable_model is an abstract type. The language doesn't allow you to use such types directly - you can only extend them. This particular usage, where you try to call a type-bound procedure of an abstract type, has been discussed among the Fortran standards committee and they agreed that such a use was not legal.
I Have simplified the code and implemented another module, in which the abstract type is extended. I am not sure if i did this correctly. I still got that error message. Can you please check this?.
[fortran]module integrable_model_module
contains
abstract interface
end interface
module integrable_model_extended_module
use integrable_model_module
! private ! Hide everything by default
! public :: integrate ! expose time integration procedure
type , extends(integrable_model) ,public :: integrable_model_extended
contains
procedure :: d_dt=>time_derivative_ex ! time derivative
procedure :: assign=>symmetric_assignment_ex ! assign one integrable_model to another
end type integrable_model_extended
contains
! there will be a warning, ignore it
function time_derivative_ex(this) result(dState_dt)
class(integrable_model_extended) ,intent(in) :: this
end function time_derivative_ex
subroutine symmetric_assignment_ex(lhs,rhs)
class(integrable_model_extended) ,intent(inout) :: lhs
end subroutine symmetric_assignment_ex
class(integrable_model_extended) :: model
model = d_dt(model) ! Explicit Euler formula
contains
end function
end subroutine
end module integrable_model_extended_module[/fortran]
A follow-up to this - after more research and discussion, we decided that this usage is legal and the compiler will be fixed in an update later this year.
Thank you. What is the expcted relase date for the next update ?
If you mean the update that includes the fix for this, I believe it is currently scheduled for sometime in October.
