ifort
Guaglardi__Paul
Was compiling and running fine for some time.
All of a sudden, I am getting this warning.
1>ifort: warning #10182: disabling optimization; runtime debug checks enabled
1>GPS_MAIN_EXE.F90
1>Linking...
1>Embedding manifest...
I cannot turn on optimization (off the debug) under any circumstances.
I used to have the optimization enabled all of the time ad indirectly enable the debugger through the RUN TIME stack frame and array bounds.
Now, nothing works.
HELP!
Steve_Lionel
What did you change? New compiler version?
It's the stack checking that is inconsistent with optimization. Turn that off. I assume you realize that debugging optimized code can be difficult since the debugger has little idea where things are.
Guaglardi__Paul
Hi Steve, thanks for your input but the stack checking is disabled.  Something has changed on own and it is confusing.  The only thing I did do was create some static arrays.
Steve_Lionel
Please zip the buildlog.htm from the Debug or Release folder (after doing a Rebuild on the project) and attach it here.
