ifort11.1 on fedora 12
vinayaksps
I have installed fedora 12 on my laptop with x_86(64 Bit). Then I have installed l_cprof_p_11.1.064. After that when I ran the program I got the following messege
/opt/intel/Compiler/11.1/064/bin/intel64/fortcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
ifort: error #10273: Fatal error in /opt/intel/Compiler/11.1/064/bin/intel64/fortcom, terminated by 0x7f
I have followed solutions of this query which have been posted earlier on this issue, e.g., installing libstdc++ etc. It has been suggested in the reference guide that ifort is compatible for fedora 10 but there is no mention of fedora 12.
I wonder if there is any nicer way to get this problem fixed.
Fedora 12 is not supported by ifort 11.1. You can try to make it work by locating and installing the compat-libstdc++ component that provides libstdc++.so.5. It's not clear to me if you did exactly that. The Release Notes also say:
If developing on an Intel 64 architecture system, some Linux distributions may require
installation of one or more of the following additional Linux components: ia32-libs,
lib32gcc1, lib32stdc++6, libc6-dev-i386, gcc-multilib
In general, you should assume that versions of Linux distributions different from what is listed in the Release Notes will not work, at least not without some additional effort on your part (if at all.) This is the way of Linux.
Ron_Green
You should have read the article:
http://software.intel.com/en-us/articles/using-intelr-compilers-for-linux-under-fedora/
listed in the Knowledge Base column on the right hand side of this forum. As Steve mentions, FC12 is unsupported, however, I do try to keep our articles on various linux distros up to date with workarounds to get these unsupported distros to work (when possible).
thanks
ron
hamid_mosaddeghi
hello Dear
I read this article and confused, ifort 11.1 prof install on fedora 12 yes or na? here say no but on article says yes????
please hekp me
I have fedora core 12 32bit andl_cprof_p_11.1.064.tgz and now how install it!!!!!!!??
thanks
Ron_Green
Yes.
Before installation:
As root user, in a terminal window:
yum install gcc
yum install gcc-c++
Next, you will need to ensure that the 32-bit version of the standard C++ library, libstdc++.so.5 (typically found
in /usr/lib/ directory) is installed on the system. The Intel C++ and Fortran compilers for Linux installation require
the linkage to the 32-bit version of libstdc++.so.5 library on all Linux distributions. Failure to do so will result in
installation failure on library dependencies not met. For more details, refer to the article at:
http://software.intel.com/en-us/articles/performance-tools-for-software-developers-intel-compiler-10x-installation-failure-libstdc-failed-dependencies/
as root user, in a terminal window, install the compatibilty library libstdc++.so.5 for 32bit AND the 32bit glibc-devel libraries
yum install compat-libstdc++-33.i686 (note:FC11, compat-libstdc++-33.i586)
yum install glibc-devel.i686 (note:FC11, glibc-devel.i586)
Then run the installation.
ron
hamid_mosaddeghi
thanks Dear Rolnald W.Green for answer
I do it, and edit /etc/bashrc
insert
export PATH=/opt/intel/Compiler/11.1/064/bin/ia32:${PATH}
export LD_LIBRARY_PATH=/opt/intel/Compiler/11.1/064/lib/ia32:${LD_LIBRARY_PATH}
and Ld path insert in /etc/ld.so.conf the typ /sbin/ldconfig -v
type in terminal which ifort >>> /opt/intel/Compiler/11.1/064/bin /ia32
now make program dl_ploy , I see this error
Permissible targets for this Makefile are:
nag-f95 (serial)
gfortran (serial)
cray-t3e (serial)
macosx (serial)
intel-linux-ifc (serial)
dec-alpha (serial)
dec-alpga-ev6 (serial)
alpha-linux (serial)
exemplar (serial)
hp-c240 (serial)
aix (serial)
rs6k (serial)
rs6k-pwr3 (serial)
pentium-absoft (serial)
pentium-portland (serial)
sg10k (serial)
sg2k (serial)
sg2k-r5k (serial)
sun-ultra (serial)
Please examine Makefile for details
[hamid@mosa srcmod]$ make intel-linux-ifc
make FC=ifc LD="ifc -o" FFLAGS="-c -O3 -w95 -w" \
LDFLAGS="-Vaxlib -static" \
EX=DLPOLY.X BINROOT=../execute seq
make[1]: Entering directory `/home/hamid/Desktop/dl_poly_2.10/srcmod'
ifc -c -O3 -w95 -w parse_module.f
make[1]: ifc: Command not found
make[1]: *** [parse_module.o] Error 127
make[1]: Leaving directory `/home/hamid/Desktop/dl_poly_2.10/srcmod'
make: *** [intel-linux-ifc] Error 2
TimP
And what happens when you specify ifort rather than ifc? IIRC, Vaxlib was an option for ifort 6 and maybe 7.
hamid_mosaddeghi
hello I add in /etc/profile
source /opt/intel/Compiler/11.1/064/bin/ifortvars.sh ia32
please help me
insert
nag-f95 (serial)
gfortran (serial)
cray-t3e (serial)
macosx (serial)
dec-alpha (serial)
exemplar (serial)
hp-c240 (serial)
aix (serial)
rs6k (serial)
rs6k-pwr3 (serial)
sg10k (serial)
sg2k (serial)
sg2k-r5k (serial)
sun-ultra (serial)
make[1]: *** [parse_module.o] Er`/home/hamid/Desktop/dl_poly_2.10/srcmod'
make: *** [intel-linux-ifc] Error 127
mecej4
The name of the Intel Fortran compiler is currently 'ifort', not 'ifc'. Do one of the following before issuing the 'make' command:
1) In your shell, declare 'ifc' as an alias for 'ifort'. For example, if you use BASH, do
alias ifc=ifort
2) Edit the makefile and change "FC=ifc" to "FC=ifort" wherever the former occurs. Similarly, change < LD="ifc -o" > to < LD="ifort -o" >.
3) Create a soft link named 'ifc' to 'ifort' accessible somewhere along your $PATH, e.g.,
ln -s /opt/IFC11/bin/ifort /home/myhome/bin/ifc
hamid_mosaddeghi
thanks
theophile__tchakoua
Hi!! All
Please I have a problem to run a program who content suroutine lapack and blas whit ifort. this is the massage:
ld: cannot find -lmkl_intel_lp64
how can I solve this problem??
Cordialy, tchaktheo
theophile__tchakoua
I'm using Kubuntu and Kubuntu 12.04
tchaktheo, please ask in Intel® Math Kernel Library
theophile__tchakoua
I'm using Ubuntu and Kubuntu 12.04
TimP
Tchakoua T. wrote:
Hi!! All
Cordialy, tchaktheo
These questions about mkl have little relationship to the prior content of the thread.  If you are using an ifort which is too old to support the -mkl option, have a look at the MKL link advisor https://software.intel.com/en-us/articles/intel-mkl-link-line-advisor
where you must enter the version of your MKL etc.
For one thing, the 32-bit version of MKL has no library named with lp64, as there is no contrasting ilp64 support.
