29260 Discussions
ifort8!! Where can I get ifort8?
zhangwei818800
I want to use ifort8.0 for linux, but where can i get thisedition,or where can i download ifort8,Thank you!
Steven_L_Intel1
Follow the instructions here - step 5 in particular.
Kevin_D_Intel
This Knowledge Base article (here) should help and you may benefit from this article (here) about installing older versions using the license file.
zhangwei818800
Thank you ,but I still cannot get intel fortran complier for linux 8, I need your help.It's too hard to find ifort8^_^
Kevin_D_Intel
I'm sorry but you will have to be more specific about what your difficulty is for us to be able to help further.
The Intel Fortran 8.0 compiler release for Linux is available from the Intel Registration Center, the same as many other ifort releases. The Knowledge base article I directed you to contains detailed steps on using the menu selection at the Registration Center for obtaining older releases of the compiler and using the license file to install those.
zhangwei818800
Quoting - zhangwei818800
I read the articles about older version and so on. But when I login on ,and choose expired submission, it just give ifort11,10what i want is ifort8, so it's a big question, Iam sorry ,who can give me the address that can download ifort8?Than you!
Steven_L_Intel1
Kevin_D_Intel
There is no direct link we can point you to. I think I might understand your confusion. I think you may be logging into the Registration center and clicking the radio box on thedefaultlanding page for Show Expired Registrations. That has nothing to do with obtaining the 8.0 Fortran release.
After logging in, on the main landing page, simply click on whatever version appears in the Download Latest Update column corresponding to the Intel Fortran Compiler Professional Edition for Linux. That should be: Version 11.1 (056). When the next screen appears, look at the bottom and you will see the version selection pull-downs discussed in step 5 of the Knowledge Base article that both Steve and I directed you to.
You can select 8.0 for the Release selection and 039 for the Update (Build #). From there you can download the full product download.
Hope that helps.
zhangwei818800
I get it!!! Ifort8.0.039.tar.gz!!!!!! Thank you!!! ThanksIntel!!!! Thank you !!! Thank you very much!!!
lele1026
I have found ifort8.0, and try to install it, but there are still many libraries missing.
Can you help me?
Steven_L_Intel1
Quoting - lele1026
Can you help me?
In another post you said you were using Fedora 11. That is not supported by ifort 8. If you insist on using ifort 8 you must restrict yourself to the specific Linux distributions and versions specified in the installation guide and release notes for ifort 8. This excludes all versions of Fedora, which did not even exist at the time ifort 8 was released.
