ifx: ICE with check bounds
Philippe31
I get an internal compiler error with ifx 2023.0.0 with this simple code:
> cat eoshift.f90
FUNCTION ZA(PA)
IMPLICIT NONE
REAL, DIMENSION(:,:,:), INTENT(IN)                :: PA
REAL, DIMENSION(SIZE(PA,1),SIZE(PA,2),SIZE(PA,3)) :: ZA
ZA(:,:,:) = EOSHIFT(PA(:,:,:),SHIFT=1,DIM=3)
END FUNCTION ZA
if I try to compile it with the -check bounds option:
> ifx -c -check bounds eoshift.f90
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1f563ca]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1bef70e]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1c55e52]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1c55f80]
/lib64/libc.so.6(+0x4ad50)[0x14fb39444d50]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x3afc702]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x3b03395]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x3b030c3]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x3b0fa22]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x3a98d52]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x3a9b859]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x3a9a87c]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2d22ced]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2031303]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2d1ad2d]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2037cd0]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x2d1af0d]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x202fe87]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b96f59]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b955dd]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b44a74]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1d028ee]
/lib64/libc.so.6(__libc_start_main+0xef)[0x14fb3942f29d]
/home/waup/installations/applications/oneapi/2023.0.0/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1982da9]
eoshift.f90: error #5633: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for eoshift.f90 (code 3)
Without the -check bounds option, compilation is OK.
Philippe
Barbara_P_Intel
The ICE when compiling with "-check bounds" is gone. I just tested an early version of 2024.2.0. This version is planned for release in mid-2024.
Barbara_P_Intel
Thank you for reporting this with such a nice reproducer. Of course, the workaround is to not compile with "-check bounds".  (Wink, since emojis don't work.)
I filed a bug report, CMPLRLLVM-45802. I'll let you know when it's fixed.
andrew_4619
That code fails (ICE)  on IFX in Windows also,
Another work around might be:
       ! REAL, DIMENSION(SIZE(PA,1),SIZE(PA,2),SIZE(PA,3)) :: ZA
        real, allocatable :: ZA(:,:,:)
That still works with bounds check on and is more pleasing on the eye IMO!
JohnNichols
Valued Contributor III
FUNCTION ZA(PA)
IMPLICIT NONE
END FUNCTION ZA
@Philippe31  - it helps make the code easy to read if you put the code into the code box in the editor.
I would have to agree with Andrew.
jimdempseyatthecove
Andrew,
ZA is the function name. Your code specifies (requires) that the callers returned-to variable/expression temporary be allocatable as well. In the OP's original code, the returned-to variable/expression temporary was (presumably) preallocated to the dimensions of that of the calling argument.
Note, with this function having a proper interface you can specify:
real :: ZA(:,:,:)
Jim Dempsey
andrew_4619
I would presume the automatic variable (array) ZA created in the function in the OPs post will be assigned to whatever the caller assigns it to whether that be allocatable or not. It is in essence the same both methods create a temporary array in the function and return that array and array descriptor. The onus is on the caller to ensure the assignment is to a compatible array IMO.
JohnNichols
Very easy to make a mistake doing this.
andrew_4619
With explicit interfaces and bound checking on it is not easy to make a mistake, the compiler is your friend!
jimdempseyatthecove
While I agree that, should this function be called returning very large arrays, the argument may require it be allocatable (such to avoid stack overflow). However, in doing so, may also require the code explicitly allocate the array should the results be generated in the return value (e.g. DO k=1,n; DO j=1,m; DO i=1,o; ... ZA(i,j,k) = scalar) as opposed to ZA = otherArrayOfDesiresShapeAndSize.
Jim Dempsey
Barbara_P_Intel
