The following minimum example code (example.f):
program example
write (*,*) 'Hello world'
endWhen compiled with:
ifx -c example.f -gen-dep=example.d
generates a correct dependency file:
example.o : \
example.f
But, when compiled with -fpp:
ifx -fpp -c example.f -gen-dep=example.d
Then, the dependency file is incorrect:
example.o : \
/tmp/ifx00788182170K24b3/ifxOJO6SA.i
The version used:
$ ifx --version
ifx (IFX) 2025.1.0 20250317
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
This error was not present with ifort.
Thanks in advance.
Bug ID is CMPLRLLVM-68142. thank you for sending this to us.
This issue still exists in 2025.2.1. Do you have a time estimation on when this is going to be fix?
The lead cylce time on OneAPI releases appears to be in the order of a year, so like all of use you just wait and see what you get. Just use IFORT and do not throw it away.
The bug is fixed in the latest 2025.3 compiler release.
