29276 Discussions
ifx, -gen-dep generates incorrect dependencies if -fpp is used
Miguel_V_
The following minimum example code (example.f):
      program example
      write (*,*) 'Hello world'
      end
When compiled with:
ifx -c example.f -gen-dep=example.d
generates a correct dependency file:
example.o : \
example.f
But, when compiled with -fpp:
ifx -fpp -c example.f -gen-dep=example.d
Then, the dependency file is incorrect:
example.o : \
/tmp/ifx00788182170K24b3/ifxOJO6SA.i
The version used:
$ ifx --version
ifx (IFX) 2025.1.0 20250317
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
This error was not present with ifort.
Thanks in advance.
Labels (2)
Ron_Green
Bug ID is CMPLRLLVM-68142. thank you for sending this to us.
Miguel_V_
This issue still exists in 2025.2.1. Do you have a time estimation on when this is going to be fix?
JohnNichols
Valued Contributor III
The lead cylce time on OneAPI releases appears to be in the order of a year, so like all of use you just wait and see what you get.   Just use IFORT and do not throw it away.
