29605 Discussions
ifx issue with function pointer result as lvalue (not yet supported)
Harald1
New Contributor II
While ifort 21.3 accepts the following code, ifx-21.3 crashes:
program p
  implicit none
  integer, target  :: ptr
  integer, pointer :: A
  ptr = 42
  print *, f()
  allocate (A, stat=f())
  print *, f()
contains
  function f()
    integer, pointer :: f
    f => ptr
  end function f
end
 ifort 21.3 prints the expected:
          42
           0
 ifx-21.3 crashes with a traceback and finally:
ifx-bug-lvalue.f90(7): error #5533: Feature found on this line is not yet supported in ifx
compilation aborted for ifx-bug-lvalue.f90 (code 3)
Harald
FortranFan
Interested readers can see this page:
https://software.intel.com/content/www/us/en/develop/articles/fortran-language-and-openmp-features-in-ifx.html
The code in the original post makes use of a Fortran 2008 feature generally referred to "Pointer function reference is a variable" that is not supported yet by IFX.
Intel Fortran team might find the code in the original post useful as a test case for IFX.
