29300 Discussions
ifx: long compilation time without optimizations (-O0)
foxtran
New Contributor II
Dear,
I have some set of files that compilation time is longer without any optimizations (-O0) rather than with any optimizations (>=-O1).
See compilation log below:
$ time ifx -O0 -c file.f -o file.f.o
real 0m15.531s
user 0m14.691s
sys 0m0.090s
$ time ifx -O1 -c file.f -o file.f.o
real 0m0.688s
user 0m0.524s
sys 0m0.047s
$ time ifx -O2 -c file.f -o file.f.o
real 0m0.923s
user 0m0.787s
sys 0m0.093s
$ time ifx -O3 -c file.f -o file.f.o
real 0m0.912s
user 0m0.809s
sys 0m0.084s
While with example file compilation time is about 15s, I have another file on which compilation time exceeds one hour without any optimizations!
With -O3 the longest file compiles just in 9s.
Please, find an example file in the attachment.
My expectation that compilation time without any optimization will be comparable with -O1 optimization level or even less.
My ifx is: ifx (IFX) 2023.2.0 20230721
Igor
foxtran
New Contributor II
Compilation with -i_tapi shows that without any optimization the pass "Fast Register Allocator" is not fast:
   ---Wall Time---  --- Name ---
  17.1798 ( 97.5%)  Fast Register Allocator
So, this pass takes almost all time of compilation.
Barbara_P_Intel
That's what I see, too, Fast Register Allocator. And that doesn't show up AT ALL at the higher opt levels!
Barbara_P_Intel
I filed a bug report, CMPLRLLVM-53405. I'll let you know when there's a fix.
Barbara_P_Intel
I just checked the compile time at -O0 with a preview version of ifx 2024.2.0. Time is 0.282s. Much better.
Look for this compiler in mid-2024.
