29276 Discussions
ifx static library linking fails with MSVC, but works with Intel C++ — LLVM backend issue?
Kuoling
I'm transitioning from ifort (classic) to ifx (LLVM-based) and hit a linking issue specific to MSVC.
When I compile a Fortran static library with ifort, it links cleanly into a C++ application built with either Intel C++ or MSVC. But when I generate the static library with ifx, linking works with Intel C++, but fails with MSVC—typically due to linking issue (unresolved symbols).
I suspect this is related to ifx being LLVM-based and generating object files (.obj) or .lib archives that are not fully compatible with MSVC's linker, especially for static linking.
  • Has anyone successfully used ifx to produce a static .lib that links into MSVC-built code?
  • Are there known issues with COFF/ABI compatibility due to the LLVM backend?
Target: Windows x64, MSVC 2022 (C++ version 19.44; SDK version 10.0.22621), Intel oneAPI 2025.2
Steve_Lionel
It would help if you showed the errors. I have built many C++/Fortran applications using the Microsoft C++ compiler and not had any issues.
