29487 Discussions
impi.dll not found when running fortran app from visual studio 2019
fernando1
I'm using Visual Studio 2019 with Intel oneapi base and HPC toolkits. When I try to use mpi in a fortran application, it builds the code correctly, but when I run it, I get the error message "can't find impi.dll". I've tried a lot of solutions but nothing works, execpt when I copy the files impi.dll and impifabric.dll to the local project directory.
SantoshY_Intel
Could you please check whether impi.dll is present in the installed oneAPI directory below:
Intel\oneAPI\mpi\2021.x.0\bin\debug
In the absence of impi.dll, please reinstall the latest oneAPI HPC & Base toolkit.
If the file is present in the directory then try adding the below lines in Project Properties -> Configuration Properties -> Build Events -> Post Build Event -> Command Line option.
copy /Y "$(I_MPI_ONEAPI_ROOT)\bin\debug\impi.dll" "$(TargetDir)"
copy /Y "$(I_MPI_ONEAPI_ROOT)\libfabric\bin\libfabric.dll" "$(TargetDir)"
Now try re-building and debugging your project. Let us know if the issue still persists.
Thanks & Regards,
Santosh
fernando1
Thanks for your answer. There are two impi.dll files, one for debug and the other for release configuration, while the libfabric.dll is the same for both configurations. I solved the problem including to the PATH variable in Configuration Properties->debugging-environment the statements:
$(I_MPI_ONEAPI_ROOT)\bin\release, for the release configuration and
$(I_MPI_ONEAPI_ROOT)\bin\debug, for the debug config.
Do you think that is a proper solution ? It works fine now.
Fernando Ribeiro
SantoshY_Intel
Glad to know that your issue has been resolved.
>>"Do you think that is a proper solution? It works fine now."
It is an official workaround provided by Intel which was documented. Please refer to the below link.
https://software.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-windows/top/compiling-and-linking/configuring-a-visual-studio-project.html
As your issue has been resolved, Could you please confirm whether to close this thread?
Awaiting your reply.
Thanks & Regards,
Santosh
fernando1
Thanks for your answer. In fact I followed the instructions in the link you sent me, but for my surprise it didn't work. For example, in the statement
  • Environment:
    PATH=$(I_MPI_ONEAPI_ROOT)\bin\$(ConfigurationName)$(I_MPI_ONEAPI_ROOT)\libfabric\bin;$(PATH)
    $(ConfigurationName) should stand for the release and debug configutations, so I had to include it manually, like this:
    PATH=$(I_MPI_ONEAPI_ROOT)\bin\$(ConfigurationName)$(I_MPI_ONEAPI_ROOT)\bin\release$(I_MPI_ONEAPI_ROOT)\libfabric\bin;$(PATH) for the release configuration and
    PATH=$(I_MPI_ONEAPI_ROOT)\bin\$(ConfigurationName)$(I_MPI_ONEAPI_ROOT)\bin\debug$(I_MPI_ONEAPI_ROOT)\libfabric\bin;$(PATH) for the debug configuration.
    That means that the environment variable $(ConfigurationName) isn't being recognized at this stage. Also I've seen others installations where the environment box doesn't even need to be specified for everything to work fine.
SantoshY_Intel
"There’s still one typo (missing semicolon) that will be fixed in the next update of the IMPI documentation".
Current,
Correct,
PATH=$(I_MPI_ONEAPI_ROOT)\bin\$(ConfigurationName);$(I_MPI_ONEAPI_ROOT)\libfabric\bin;$(PATH)
Please let us know if you still face the issue.
Thanks & Regards,
Santosh
fernando1
I have included the semicolons but it still doesn't work. There is something wrong with my installation related to the PATH.
I have seen some installations that its not necessary to specify these environment variables.
SantoshY_Intel
Could you please let us know the Visual studio version you have been using?
Santosh
fernando1
SantoshY_Intel
We have not heard back from you. Is your issue resolved? If not, could you please let us know the Visual Studio version you have been using?
Santosh
SantoshY_Intel
As we have not heard back from you, we are considering that your issue has been resolved. So we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day!
Thanks & Regards
Santosh
