29285 Discussions
initialize Variable in declaration section of a Subroutine
Ho__Matthias
When I initialize a Variable in a Subroutine within the declaration section, the initialization is just executed in the first run of the Subroutine. In the second run, the old (saved?) value is used.
As a minimal example I have the following code with the output 1 and 5 instead of two times the 1.
Does someone understand this feature?
Program Test
Implicit none
Call Sub1( )
Call Sub1( )
contains
   Subroutine Sub1( )
   Implicit None
   Integer*4 :: j1=1
   Print*, j1
   j1=5
   End Subroutine Sub1
End Program Test
Ho__Matthias
Sorry for the wrong formatting! The text again:
TimP
The initializer has effect only the first time.  This has been a feature of the standard since this form of initializer was adopted (f90).  Declaring with initializer also has the effect of SAVE, so the value upon leaving the procedure remains visible on reentry.  Using the non-standard extension integer*4 doesn't make the compiler revert partially to the behavior of some compiler from the early days of this extension. If you set a -stand option, you should get a warning (but not about the compiler not mimicking an old extended Fortran 66 behavior).
