Hello .
i using Intel Fortran Compiler for Windows product.
Following error happen..
c: emp>ifl /zi /Od /w95 test.f90
ifl : error: could not find 'link'
And following error happen.
efl: error: unable to run 'c:program filesmicrosoft SDKinwin64link'
If there is no method that i can solve this problem ?
I will ask reply.
I will ask reply.
I suggest starting your command session with the appropriate "build environment" shortcut in the Intel Fortran program group. Part of the problem seems to be that the Microsoft VC++ BIN folder is not in your path. I'n not sure about the efl issue - please contact Intel Prenmier Support if you continue to have problems.
Steve
Steve
