installation of iFortran
yuang06
Dear all,
I downloaded l_fcompxe_2011.9.293.tgz. Can I install it under Cygwin with Win7 environment? It is supposed to be for Linux while Cygwin emulates Unix.
I extracted files from the above compressed .tgz, but errors occured when I tried to install it with the command:
$ ./install.sh, (I saw this file in the folder after extraction.)
The error information is below:
./install.sh : line 300 : /sbin/ldconfig: no such file or directory
Could you please help solve this problem? Thanks.
Best Regards
Ang
TimP
Read the cygwin faq. Cygwin doesn't offer linux emulation. It works well as a shell enviornment with windows ifort installed normally. Ifort can't make a "native cygwin" application (linked against cygwin .dll), although (for 32-bit applications only) the cygwin link and libtools should work.
