integer(8) causes array temperary
abhimodak
Hi
In the sample below: changing integer to integer(8) is giving an array-temporary. Is standard violated by the program (in subroutine Method's argument declarations for arrays A and B)?
Compile with "ifort /check:arg_temp_created". I am using XE 2015 Update 2 package 179 with VS2012.
Abhi
   Module OM
      Implicit None
      !Integer :: KK
      Integer(8) :: KK
   Contains
      Subroutine Method(A, B)
         Real(8), Intent(INOUT) :: A(KK,KK), B(KK)
         A = 0.0d0; B = 1.0d0
      End Subroutine Method
   End Module OM
   Module Shree
      Use OM
   Contains
      Subroutine Set(C)
         Real(8), Intent(IN), Target :: C(KK*KK+KK)
         Real(8), Pointer :: pC(:) => Null()
         pC => C
         Call Method(pC(1:), pC(KK*KK+1:))
      End Subroutine Set
   End Module Shree
   Program Test
      Use Shree
      Implicit None
      Real(8), Allocatable :: C(:)
      Print *, "Give KK"
      Read *, KK
      Allocate(C(KK*KK + KK))
      Call Set(C)
      Print *, C(KK)
   End Program Test
There's nothing wrong with your code. Adjustable arrays are classic Fortran (though the use of host association is a bit newer.) The compiler is being a bit stupid here - I will let the developers know. Since pC is a pointer, the run-time code does have to check for contiguity, but apparently the use of an INTEGER(8) subscript throws it off.
Well, there IS something wrong with your code, but it doesn't change the fact that the compiler is being silly.
Subroutine Method changes the value of Set's dummy argument C through both the A and B dummy arguments. Because A and B don't have TARGET, this violates the following restriction in the standard (12.5.2.13p1(3)):
While an entity is associated with a dummy argument, the following restrictions hold.
Action that affects the value of the entity or any subobject of it shall be taken only through the dummy argument unless
  (a) the dummy argument has the POINTER attribute or
  (b) the dummy argument has the TARGET attribute, the dummy argument does not have INTENT (IN), the dummy argument is a scalar object or an assumed-shape array without the CONTIGUOUS attribute, and the actual argument is a target other than an array section with a vector subscript.
However, adding TARGET to A and B doesn't change the behavior. Issue ID is DPD200379423.
jimdempseyatthecove
Wouldn't C in PROGRAM also require TARGET?
Jim Dempsey
I don't think so. The restrictions are on the dummy argument.
JVanB
Valued Contributor II
What about the part where it says "and the actual argument is a target"?
abhimodak
Hi
I noticed this after posting the example -- There should be Intent(INOUT) for C in subroutine Set.
Abhi
This issue has been fixed for the next major release, due out in the second half of 2016. The compiler will then consider additional types of expressions for generating the run-time contiguity check.
jimdempseyatthecove
Yea! I hope it catches all instances of unnecessary array temporaries.
Jim Dempsey
