29286 Discussions
intel Fortran Compiler 9.0 on Fedora Core 4
kawai
Hi Hi,
i have biult a platformof Intel P4 660 EM 64T with OS Fedora Core4 and i have installed Intel Math lib 7.2.1 and Fortran compiler 9.0 to test 64-bit performance
But when itried to compileprograms,
it gave me the following error message:
rm -f vasp
ifort -i_dynamic -o vasp main.o base.o mpi.o smart_allocate.o xml.o constant.o jacobi.o main_mpi.o scala.o asa.o lattice.o poscar.o ini.o setex.o radial.o pseudo.o mgrid.o mkpoints.o wave.o wave_mpi.o symmetry.o symlib.o lattlib.o random.o nonl.o nonlr.o dfast.o choleski2.o mix.o charge.o xcgrad.o xcspin.o potex1.o potex2.o metagga.o constrmag.o pot.o cl_shift.o force.o dos.o elf.o tet.o hamil.o steep.o chain.o dyna.o relativistic.o LDApU.o sphpro.o paw.o us.o ebs.o wavpre.o wavpre_noio.o broyden.o dynbr.o rmm-diis.o reader.o writer.o tutor.o xml_writer.o brent.o stufak.o fileio.o opergrid.o stepver.o dipol.o xclib.o chgloc.o subrot.o optreal.o davidson.o edtest.o electron.o shm.o pardens.o paircorrection.o optics.o constr_cell_relax.o stm.o finite_diff.o elpol.o setlocalpp.o fft3dfurth.o fft3dlib.o -L../vasp.4.6.lib -ldmy ../vasp.4.6.lib/linpack_double.o -L/opt/intel/mkl721/lib/em64t -lmkl_lapack64 -L/opt/intel/mkl721/lib/em64t -lmkl_p4n -lpthread -lsvml -lguide -lpthread
IPO link: can not find "../vasp.4.6.lib/linpack_double.o"
ifort: error: problem during multi-file optimization compilation (code 1)
make: *** [vasp] Error 1
What's the problem??
Can anyone help me??
TimP
As you see, when you confuse the linker, the error messages aren't helpful. Do you have a reason for scrambling the order of .o files and library directives? Are you trying to use a 32-bit mkl library together with 64-bit mkl? You can't mix 32- and 64-bit .o and library files. "can not find.." is a usual ld message when you supply a 32-bit .o where 64-bit is expected. The other possibility, if ld agrees to a mixed link, is that your application suspends at the point where you try to switch between 32- and 64-bit code.
Lester
I'm sorry, could you explain your comment about confusing the linker. I've started having a similiar problem with fc9.0 since I've installed FC4. I didn't have it with FC3, so its not entirely the compiler's problem, but the Lahey compiler doesn't have the problem. My system is entirely 32 bits, so there is no problem with mixed sizes. Below are results from 2 different executions. The only difference is that the successful execution actually had to compile a dummy deck, while the execution that should only have executed the loader failed.
Failed:
ifort -o lsulib lsulib.o -L../lib -llsulib -lscale
IPO link: can not find "("
Succeeded:
ifort -o lsulib lsulib.o ../dummy.f90 -L../lib -llsulib -lscale
kawai
Hi Hi,
As i am a starter for using Fortran compiler 9.0,
Could you mind explain to me thatwhere i have confuse the linker ??
Thanks!!!
cond0025
After recently upgrading from Fedora Core 3 to Fedora Core 4 I'm experiencing a similar problem. For example:
ifort -c analytic_approx.F90 -o analytic_approx.o90
ifort -c qromb.f -o qromb.o
ifort -c polint.f -o polint.o
ifort -c trapzd.f -o trapzd.o
ifort analytic_approx.o90 qromb.o polint.o trapzd.o -o analytic_approx.exe
If I avoid creating object files it works OK, i.e.:
ifort analytic_approx.F90 qromb.f polint.f trapzd.f -o analytic_approx.exe
is successful.
Alternatively, I can make this work by switching off all optimizations:
ifort -c analytic_approx.F90 -o analytic_approx.o90 -pthread -pad -Vaxlib -mp -save -O0 -w95 -extend_source
ifort -c qromb.f -o qromb.o -pthread -pad -Vaxlib -mp -save -O0 -w95 -extend_source
ifort -c polint.f -o polint.o -pthread -pad -Vaxlib -mp -save -O0 -w95 -extend_source
ifort -c trapzd.f -o trapzd.o -pthread -pad -Vaxlib -mp -save -O0 -w95 -extend_source
ifort analytic_approx.o90 qromb.o polint.o trapzd.o -o analytic_approx.exe -pthread -pad -Vaxlib -mp -save -O0 -w95 -extend_source
is successful.
Not to give in too easily, here's what I tried next:
1) Try compiling with -O3 again:
ifort -c analytic_approx.F90 -o analytic_approx.o90 -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source
ifort -c qromb.f -o qromb.o -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source
ifort -c polint.f -o polint.o -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source
ifort -c trapzd.f -o trapzd.o -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source
ifort analytic_approx.o90 qromb.o polint.o trapzd.o -o analytic_approx.exe -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source
failed as expected.
2) The linker appears to be looking for "(", so let's create it (I just create a dummy file):
echo null > (
IPO link: can not find "AS_NEEDED"
3) Now it's looking for "AS_NEEDED" so:
echo null > AS_NEEDED
which now works successfully.
I have no idea why the linker is looking for these two files. But creating them seems to placate it. If anyone knows what's going on here it wou ld be nice to have a mor elegant solution!
Hope this helps with your problem.
-Andrew.
It would be useful to see the output of the ifort command doing the linking that has the -dryrun switch added. This will show the exact commands passed to ld.
Note that we do not claim support for Fedora.
cond0025
Here's the output when using -dryrun:
$ ifort analytic_approx.o90 qromb.o polint.o trapzd.o -o analytic_approx.exe -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source -dryrun
/opt/intel/fc/9.0/bin/fortcom
-mP1OPT_version=900
-mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90
-mGLOB_tune_for_fort
-mGLOB_use_fort_dope_vector
-mP2OPT_static_promotion
-mP1OPT_print_version=FALSE
-mP3OPT_use_mspp_call_convention
-mCG_use_gas_got_workaround=F
-mP2OPT_align_option_used=TRUE
"-mGLOB_options_string=-o analytic_approx.exe -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source -dryrun"
-mGLOB_cxx_limited_range=FALSE
-mGLOB_as_output_backup_file_name=/tmp/ifort76bTmKas_
-mGLOB_machine_model=GLOB_MACHINE_MODEL_IA32_NONE
-mGLOB_maintain_precision
-mGLOB_precision_mask=0xffffffff
-mP2OPT_pad_local
-mP2OPT_subs_out_of_bound=FALSE
-mIPOPT_ninl_user_level=2
-mGLOB_opt_level=3
-mIPOPT_activate
-mP2OPT_hlo_level=2
-mP2OPT_hlo
-mIPOPT_link
-mIPOPT_ipo_activate
-mIPOPT_whole_program
-mIPOPT_ipo_mo_activate
-mIPOPT_ipo_mo_nfiles=1
-mIPOPT_source_files_list=/tmp/ifortMeW32Zlst
-mIPOPT_short_data_info=/tmp/ifortROJYCGsdata
-mIPOPT_link_script_file=/tmp/ifortszHTcnscript
-mIPOPT_global_data
"-mIPOPT_link_version=2.15.94.0.2.2 20041220"
"-mIPOPT_cmdline_objs="analytic_approx.o90" "qromb.o" "polint.o" "trapzd.o""
"-mIPOPT_cmdline_link="/usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crt1.o" "/usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crti.
o" "/usr/lib/gcc/i386-redhat-linux/4.0.0/crtbegin.o" "-dynamic-linker" "/lib/ld-linux.so.2" "-m" "elf_i386" "-o" "analytic_approx.exe
" "/opt/intel/fc/9.0/lib/for_main.o" "analytic_approx.o90" "qromb.o" "polint.o" "trapzd.o" "-L/opt/intel/fc/9.0/lib" "-L/usr/lib" "-B
static" "-lifport" "-lifcoremt" "-Bdynamic" "-limf" "-lm" "-lpthread" "-Bstatic" "-lirc" "-Bdynamic" "-lc" "-Bstatic" "-lirc_s" "-Bdy
namic" "-ldl" "-lc" "/usr/lib/gcc/i386-redhat-linux/4.0.0/crtend.o" "/usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crtn.o""
-mIPOPT_save_il0
-mIPOPT_il_in_obj
-mIPOPT_link_silent
-mIPOPT_obj_output_file_name=/tmp/ipo_ifortQqLeTC.o
"-mGLOB_linker_version=2.15.94.0.2.2 20041220"
-mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS
-mGLOB_obj_output_file=/tmp/ipo_ifortQqLeTC.o
-mP1OPT_source_file_name=/tmp/ipo_ifortQqLeTC.f
analytic_approx.o90
qromb.o
polint.o
trapzd.o
-mIPOPT_object_files=/tmp/ifortmvi9sjtxt
ifort: warning: couldn't open multi-file optimizations object list
ld
/usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crti.o
-dynamic-linker
/lib/ld-linux.so.2
-m
elf_i386
-o
analytic_approx.exe
-L/usr/lib
-Bstatic
-lifport
-lifcoremt
-Bdynamic
-limf
-lm
-lpthread
-Bstatic
-lirc
-Bdynamic
-lc
-Bstatic
-lirc_s
-Bdynamic
-ldl
-lc
--sort-section
name
rm /tmp/ifortmvi9sjtxt
rm /tmp/ifortMeW32Zlst
rm /tmp/ifortROJYCGsdata
rm /tmp/ifortszHTcnscript
rm /tmp/ipo_ifortQqLeTC.o
rm /tmp/ifortfaLOM3gas
rm /tmp/ifort76bTmKas_
rm /tmp/ifortYOnYWqld
rm /tmp/ifortZyltx7arg
Ok, let's try this. Replace -dryrun with:
-i_save_temps -#x
Look in the output for the line similar to:
Note the name of the file in the new output line and "cat" it to see what it contains.
cond0025
OK - here goes:
$ ifort analytic_approx.o90 qromb.o polint.o trapzd.o -o analytic_approx.exe -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source -i_save_temps -#x
-mP1OPT_version=900
"-mGLOB_options_string=-o analytic_approx.exe -pthread -pad -Vaxlib -mp -save -O3 -w95 -extend_source -i_save_temps -#x"
-mGLOB_as_output_backup_file_name=/tmp/ifortQDMrAjas_
-mP2OPT_pad_local
-mGLOB_opt_level=3
-mIPOPT_activate
-mP2OPT_hlo_level=2
-mP2OPT_hlo
-mIPOPT_link
-mIPOPT_source_files_list=/tmp/ifortPQnqMMlst
-mIPOPT_short_data_info=/tmp/ifortMqtTtasdata
-mIPOPT_link_script_file=/tmp/ifortNMEmbyscript
-mIPOPT_global_data
"-mIPOPT_cmdline_link="/usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crt1.o" "/usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crti.o" "/usr/lib/gcc/i386-redhat-linux/4.0.0/crtbegin.o" "-dynamic-linker" "/lib/ld-linux.so.2" "-m" "elf_i386" "-o" "analytic_approx.exe" "/opt/intel/fc/9.0/lib/for_main.o" "analytic_approx.o90" "qromb.o" "polint.o" "trapzd.o" "-L/opt/intel/fc/9.0/lib" "-L/usr/lib" "-Bstatic" "-lifport" "-lifcoremt" "-Bdynamic" "-limf" "-lm" "-lpthread" "-Bstatic" "-lirc" "-Bdynamic" "-lc" "-Bstatic" "-lirc_s" "-Bdynamic" "-ldl" "-lc" "/usr/lib/gcc/i386-redhat-linux/4.0.0/crtend.o" "/usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crtn.o""
-mIPOPT_save_il0
-mIPOPT_il_in_obj
-mIPOPT_link_silent
-mIPOPT_obj_output_file_name=/tmp/ipo_ifortogEun1.o
-mGLOB_obj_output_file=/tmp/ipo_ifortogEun1.o
-mP1OPT_source_file_name=/tmp/ipo_ifortogEun1.f
analytic_approx.o90
qromb.o
polint.o
trapzd.o
-mIPOPT_object_files=/tmp/ifortaisX4otxt
keeping /tmp/ifortaisX4otxt
keeping /tmp/ifortPQnqMMlst
keeping /tmp/ifortMqtTtasdata
keeping /tmp/ifortNMEmbyscript
keeping /tmp/ipo_ifortogEun1.o
keeping /tmp/ifortsjZPSVgas
keeping /tmp/ifortQDMrAjas_
keeping /tmp/ifortuvW3hHld
keeping /tmp/ifort1XnT04arg
$ cat /tmp/ifortaisX4otxt analytic_approx.o90
qromb.o
polint.o
trapzd.o
There doesn't appear to be anything unusual in this file.
-Andrew.
Look at the other temp files to see if you can spot anything odd.
chik0010
Hi there !
I have exactly same problem! From this topic I got that if I compile without object files everything should work, which is indeed the fact. But I am trying to install mpich-1.2.7 on my 2 x Opteron FC4 machine and the installation failed
configure:1536: checking whether Fortran 90 is compatible with Fortran 77
configure:1537: ifort -c conftest.f90 1>&5
configure:1539: ifort -c conftest1.f
configure:1541: ifort -o conftest conftest.o conftest1.o
Anybody knows how to overcome it? Or any suggestion which compiler to use instead ifort for 64bit computing?
thank you
Ivan
kawai
Hi Hi,
I followed the suggestion as Andrew said, just by making two files by
1) echo null > (
2) echo null > AS_NEEDED
Then, it was compiled successfully. But the speed is very slow when comparing to previous intel Fortran compiler.
another choice for 64 bit fortran compiler is PGI, you can make a trial.
Thanks!!
From
Kawai.
chik0010
THank you for the quick reply !!
I got that if I want to compile my own code with the makefile I should create these two file, and in fact everything is working perfectly, but my goal is to install MPICH on my machine.
Installation process is standard.
1) ./configure -- all the parameters
2) ./make
after step one configurator supposed to create all the files necessary to compile (makefiles) but instead of that in some of the folders I can see in config.log
I am not sure where should I put ( and AS_NEEDED files. therefore I prefer change default optimization level to -O0 which I understand can also help. but I do not know there can I change it globally.
Thank you in advance,
Ivan
This seems to have been triggered by a new linker feature that the Intel interprocedural optimization tool doesn't recognize. A workaround is to add -O0 on the ifort line that links the application.
mezacoe
Hi
I have this problem.. I am working with ncar graphic, 32 bits
ncargf77 -xW pltave.o /home/Omar/contrail/wvu_cc_v1.6.0/lib/library/lib/libarap.a
-o /home/Omar/contrail/wvu_cc_v1.6.0/bin/pltave
ifort -O -xW pltave.o /home/Omar/contrail/wvu_cc_v1.6.0/lib/library/lib/libarap.a -o /home/Omar/contrail/wvu_cc_v1.6.0/bin/pltave -L/usr/local/ncarg/lib -L/usr/X11R6/lib -lncarg -lncarg_gks -lncarg_c -lX11 -lXext
make: *** [/home/Omar/contrail/wvu_cc_v1.6.0/bin/pltave] Error 1
***Build Process Failed***
Message Edited by mezacoe on 09-10-2005 10:53 PM
See my suggestion just above your post.
mezacoe
Hi Steve
I will try your idea in my PC, but I have other problem in other PC
ncargf77 -xW pltave.o /home/omar/nc160/wvu_cc_v1.6.0/lib/library/lib/libarap.a -o /home/omar/nc160/wvu_cc_v1.6.0/bin/pltave
ifort -O -xW pltave.o /home/omar/nc160/wvu_cc_v1.6.0/lib/library/lib/libarap.a -o /home/omar/nc160/wvu_cc_v1.6.0/bin/pltave -L/usr/local/ncarg/lib -L/usr/X11R6/lib -lncarg -lncarg_gks -lncarg_c -lX11 -lXext
IPO link: can not find -lX11
IPO link: can not find -lXext
IPO Error: unresolved : s_cmp
Referenced in libncarg.a(agsetc.o)
Referenced in libncarg.a(icfell.o)
Referenced in libncarg.a(agsetp.o)
Referenced in libncarg.a(agppid.o)
Referenced in libncarg.a(icloem.o)
Referenced in libncarg.a(agscan.o)
Referenced in libncarg.a(agsrch.o)
Referenced in libncarg.a(getusv.o)
Referenced in libncarg_gks.a(gerlog.o)
Referenced in libncarg_gks.a(g01wdr.o)
Referenced in libncarg_gks.a(gwiwdr.o)
Referenced in libncarg_gks.a(gtnlen.o)
Referenced in libncarg_gks.a(g01msg.o)
IPO Error: unresolved : s_copy
Referenced in libncarg.a(seter.o)
Referenced in libncarg.a(agcurv.o)
Referenced in libncarg.a(aggtch.o)
Referenced in libncarg.a(agaxis.o)
Referenced in libncarg.a(agnumb.o)
Referenced in libncarg.a(dashdc.o)
Referenced in libncarg_gks.a(gerhnd.o)
Referenced in libncarg_gks.a(gzopwk.o)
Referenced in libncarg_gks.a(gesc.o)
Referenced in libncarg_gks.a(gzputs.o)
Referenced in libncarg_gks.a(gdsg.o)
Referenced in libncarg_gks.a(gzgte2.o)
Referenced in libncarg_gks.a(g01snp.o)
Referenced in libncarg_gks.a(g01seg.o)
Referenced in libncarg_gks.a(g01clw.o)
IPO Error: unresolved : s_cat
IPO Error: unresolved : s_wsfe
Referenced in libncarg.a(eprin.o)
Referenced in libncarg.a(agexax.o)
Referenced in libncarg_c.a(i1mach.o)
IPO Error: unresolved : do_fio
Referenced in libncarg_gks.a(grqst.o)
Referenced in libncarg_gks.a(gzreop.o)
IPO Error: unresolved : e_wsfe
IPO Error: unresolved : s_stop
Refe renced in libncarg_gks.a(g01seg.o)
IPO Error: unresolved : s_wsfi
IPO Error: unresolved : e_wsfi
IPO Error: unresolved : s_rsfi
IPO Error: unresolved : e_rsfi
IPO Error: unresolved : s_wsle
IPO Error: unresolved : do_lio
IPO Error: unresolved : e_wsle
IPO Error: unresolved : XCopyColormapAndFree
Referenced in libncarg_gks.a(xcontrol.o)
Referenced in libncarg_gks.a(pixcontrol.o)
IPO Error: unresolved : XCreateColormap
IPO Error: unresolved : XQueryColors
Referenced in libncarg_gks.a(pixwrite_xwd.o)
IPO Error: unresolved : XStoreColors
IPO Error: unresolved : XFreeColormap
IPO Error: unresolved : XSetWindowColormap
IPO Error: unresolved : XAllocColor
Referenced in libncarg_gks.a(xattribute.o)
Referenced in libncarg_gks.a(pixattribute.o)
IPO Error: unresolved : XCreateGC
Referenced in libncarg_gks.a(xoutput.o)
Referenced in libncarg_gks.a(pixoutput.o)
IPO Error: unresolved : XFreeColors
IPO Error: unresolved : XCheckMaskEvent
IPO Error: unresolved : XMaskEvent
IPO Error: unresolved : XGetDefault
IPO Error: unresolved : XParseGeometry
IPO Er ror: unresolved : XCreateWindow
IPO Error: unresolved : XSetWMProperties
IPO Error: unresolved : XSelectInput
IPO Error: unresolved : XMapWindow
IPO Error: unresolved : XNextEvent
IPO Error: unresolved : XCheckTypedEvent
IPO Error: unresolved : XInternAtom
IPO Error: unresolved : XSetWMProtocols
IPO Error: unresolved : XOpenDisplay
IPO Error: unresolved : XGetWindowAttributes
IPO Error: unresolved : XFreeGC
IPO Error: unresolved : XCloseDisplay
IPO Error: unresolved : XSync
IPO Error: unresolved : XClearWindow
IPO Error: unresolved : XQueryBestStipple
IPO Error: unresolved : XCreatePixmap
IPO Error: unresolved : XFreePixmap
IPO Error: unresolved : XSetFunction
IPO Error: unresolved : XFillPolygon
IPO Error: unresolved : XDrawLine
IPO Error: unresolved : XSetStipple
IPO Error: unresolved : XSetFillStyle
IPO Error: unresolved : XDrawLines
IPO Error: unresolved : XCreateImage
IPO Error: unresolved : XPutImage
IPO Error: unresolved : XDrawArc
IPO Error: unresolved : XDrawPoint
IPO Error: unresolved : XSetForeground
IPO Error: unresolved : XSetDashes
IPO Error: unresolved : XChangeGC
IPO Error: unresolved : XSetWindowBackground
IPO Error: unresolved : XSetClipRectangles
IPO Error: unresolved : XSetClipMask
Referenced in libncarg_gks.a(xinquiry.o)
Referenced in libncarg_gks.a(pixinquiry.o)
IPO Error: unresolved : XGetGeometry
Referenced in libncarg_gks.a(pixwrite_png.o)
IPO Error: unresolved : XFillRectangle
IPO Error: unresolved : XCopyArea
IPO Error: unresolved : XGetImage
ld: cannot find -lX11
make: *** [/home/omar/nc160/wvu_cc_v1.6.0/bin/pltave] Error 1
I do not know if is problem with ncar graphic or fortran compiler 9.0
Thanks a lot Steve
Omar
TimP
Here, you have linked a library which requires libf2c. Presumably, the library was built with g77. In general, those libf2c run-time functions are incompatible with ifort (and other compilers, including gfortran). It's best to build the entire application with a single Fortran compiler.
gunduz
I have a AMD Turion 64 bit, laptop. I have installed the fedora core4 on it.
I want to install the ifort 9.0. After downloading the ifort packages, I have run the install.sh script. Evev after 20 minutes, there is nothing appears in my screen.
I am expecting a menu consist of numbers, asking me I want to do,
but nothing happens, Iechosomewhere in the script to follow it.
itis working very well untill the $install_prog
which is
./secore -t --launch
after that command scripts waiting.Do you have any idea, what is wrong?
Could you please help me to solve the problem?
Thanks in advance,
Murat
TimP
I've heard other reports of Turion failing to support code which runs on Opteron, P4, and Pentium-M, but you may want to try the following:
I've seen 2 varieties of failure at install time which could be bypassed by the lower level install script
./install_fc --run
If you report the problem on premier.intel.com, you may be asked to collect and return some diagnostics,
If you find information from someone who has reverse engineered Turion to find out what instructions it supports, or does not, that also might be interesting.
On the other hand, we have several reports of secore (which is the Intel Software Setup Assistant) hanging, even on supported systems. Please report the problem to Intel Premier Support.
