intel + copyprivate wrong error
valery_w_
dear all
ifort produces a wrong error with the following codethanks
v
ifort -v
ifort version 14.0.1
cat ifort_14.0.1_copyprivate.f90
program test
  use omp_lib
  implicit none
  integer :: b
  !$omp parallel
  !$omp end parallel
  !$omp parallel  private (b)
  !$omp single
  b = omp_get_num_threads ()
  !$omp end single copyprivate (b)
  write(*,*) b
  !$omp end parallel
end program test
ifort -openmp ifort_14.0.1_copyprivate.f90
ifort_14.0.1_copyprivate.f90(12): error #7982: Variables in the COPYPRIVATE list must be PRIVATE in the enclosing parallel region.
compilation aborted for ifort_14.0.1_copyprivate.f90 (code 1)
Jonathan_B_
I got the same error; the error goes away when lines 6 and 7
[fortran]!$omp parallel
!$omp end parallel[/fortran]
are commented out or removed.
[bash]ifort -v
ifort version 13.1.0[/bash]
and
[bash]ifort -v
ifort version 14.0.1[/bash]
Kevin_D_Intel
Thank you for notifying us about this error. I reported this to Development and will update this post as I hear more.
(Internal tracking id: DPD200250671)
(Resolution Update on 09/15/2014): This defect is fixed in the Intel® Parallel Studio XE 2015 Initial Release (2015.0.090 - Linux)
Kevin_D_Intel
I confirmed this issue is resolved in the Intel® Parallel Studio XE 2015 release for Linux (Version 15.0.0.090 Build 20140723) now available from the Intel® Registration Center.
