interdependence of indices in DO CONCURRENT
Espen_M_
The following DO statement compiles on IFORT 13.1.3.198 [IA-32]:
[fortran]
DO CONCURRENT (i = 1:SIZE(arr1d), j = 1:i-1)
[/fortran]
According to the F08 draft (N1830), C739 it is not permitted to
reference to any index-name in the forall-triplet-spec-list in which it appears
, and if I use the same forall-header in a FORALL statement the error is catched.
Is this allowed or not?
FortranFan
Not allowed going strictly by the standard - don't know if Intel Fortran has an extension that allows this.  Do you get error(s) if the standards checking is turned on?  If not, then it seems like a compiler bug.  Did you try compiler 14, update 2?  Possibly fixed in there.
Steven_L_Intel1
Still a bug - escalated as issue DPD200254821. Not a deliberate extension.
