internal compiler error
hoda_j_
Hi everybody
I need your help.it is very necessary for me.I have writen my code in compaq visual fortran.my problem is that I export three matrices from maple and use them in fortran program.my matrices have became bigger.and now when I want to compile the program I encounter this error   "f90 internal  compiler error c 000005".
what should I do?
I apperciate your help.
You should report the problem to us and provide the source in question, any include or module source (not .mod)  files needed to reproduce the error, the exact command used to invoke the compiler and the exact compiler version used. You can do that here or through Intel Premier Support.
hoda_j_
I thank you very much, but my fortran codes size is large.also I donthave permission to put it in a public place.if it is possible for you I will mail it to you.my code is written in compaq visual fortran version 6.5
