serial code, rum time analysis
diedro
Dear all,
I have written a serial code in Fortran with intel composer linux. I would like to analyse the time that the program in each subroutine.
I know that I can use CALL CPU_TIME(time), but I would like to know if there is some tool to do that automatically.
I hope that I make me clear.
thanks a lot
TimP
ifort options such as -profile-loops, -profile-functions
ifort and most other compilers support gprof.
Where did the marketing people miss you when advertising profilers like VTune, as well as open source tools such as oprofile>
diedro
Dear Tim,
thanks a lot.
I try to compile my code:
ifort -r8 -profile-loops-report=2  *.f90 -lmkl_blas95_lp64 -lmkl_lapack95_lp64 -mkl=sequential
This is what I have found in the documentation:
https://software.intel.com/sites/products/documentation/doclib/iss/2013/compiler/cpp-lin/GUID-96F454BF-364A-40C9-9B55-BFFAA8FD171D.htm
however, I am not able to get the output file.
Do I have to run the executable file with some options? The documentation seems to be not so clear.
Thanks a lot
TimP
I guess the comments in that reference about where to find the output files may not apply to current compiler versions.  There may be a subdirectory created which contains outputs.
The full compiler documentation states that profile-loops-report will not work without profile-loops.
