internal consistency error
Ray_R_1
Hello, I have been working on converting a 32 bit qwin program to emt64, using IVF 10. When I compile the program using the 32 bit compiler (either in debug mode, no optimizing or in release mode, full max speed optimizing) life is good. If I compile it with the 64 bit compiler with optimization turned off life is still good, when I try turning on the optimization life gets bad and the error of the day is "forrtl: severe(8): internal consistency check failure file for_intrp_fmt.c line 2084". Can someone tell me what this error is?
Well, like it says, something went wrong internally to the library. Please submit a report to Intel Premier Support and attach a ZIP of the application project so that we can take a look at it.
