I stumbled upon compiler allowing internal procedure passed as argument. I believe the standard prohibits doing so. The snippet below would thus compile without error and actual steps into subroutine Model from program Test.
Abhi
Program TestImplicit None
Integer, Parameter :: N = 5
External :: Library
Call Library(N, Model)
Contains
Subroutine Model(n)
Implicit None
Integer, Intent(IN) :: n
Print *, n
End Subroutine Model
End Program Test
Subroutine Library(n, Model)
Implicit None
Interface
Subroutine Model(n)
End Interface
Call Model(n)
End Subroutine Library
This is an extension to F2003 that we support. It is standard-conforming in F2008. Note that the standard describes a standard-conforming program. If you compiled this with standards checking, you'd see:
t.f90(8): warning #7601: F2003 standard does not allow an internal procedure to be an actual argument procedure name. (R1214.4). [MODEL]
Yes, quite right. Thanks!
Abhi
