29650 Discussions
interoperability with C structs through c_f_pointer
damienhocking
All,
I'm having trouble accessing the members of a C struct that has an equivalent Fortran struct. The C struct is allocated over on the C side and the library returns a pointer to that struct back to the Fortran caller. I then use c_f_pointer to convert that to a Fortran pointer and attempt to access the contents of the Fortran struct, and when running this produces the error "Attempt to use pointer PVTPKGFORT when it is not associated with a target". I started running into this in our QC tests; it runs fine inside the Visual Studio debugger but in the console or QC scripts it throws the error.
This is the C struct, allocated and deallocated over in the C code:
struct MDLPVT_C
int numcomps_;
int numphases_;
The corresponding Fortran struct is:
type, bind(c) :: MDLPVT_C_FORT
integer(c_int) :: numcomps_
integer(c_int) :: numphases_
end type MDLPVT_C_FORT
The interface to the C function that allocates the C struct is:
function BuildPVT_C() result(pvt) bind(C, name="BuildPVT_C")
use, intrinsic :: ISO_C_BINDING
type(c_ptr) :: pvt
end function BuildPVT_C
 This sets the values of numcomps_ and numphases_ in the struct as well.
The (cut down) Fortran code is:
type(c_ptr) :: pvtpkg
type(MDLPVT_C_FORT), pointer :: pvtpkgfort
pvtpkg = BuildPVT_C()
call c_f_pointer(pvtpkg, pvtpkgfort)
write(*,*) 'Loaded PVT package'
write(*,*) 'PVT has ', pvtpkgfort%numcomps_, ' components'
Trying to access pvtpkgfort%numcomps_ is what produces the error.
Going through the Intel docs for c_f_pointer it says: "If the value of cptr is the C address of an interoperable data entity, fptr must be a data pointer with type and type parameters interoperable with the type of the entity. In this case, fptr becomes pointer-associated with the target of cptr." I thought that's what I've done, but obviously there's something missing.
I've tried adding the target attribute to pvtpkg and c_loc(pvtpkg) in the c_f_pointer call, which removes the error message in the console but then the pvtpkgfort struct member values are set to garbage. Do I need a shape argument in the c_f_pointer call?
This must be something simple. Can anyone tell me what I'm doing wrong?
Damien
Steve_Lionel
If you're getting that error, it suggests to me that BuildPVT_C is returning a null pointer. You haven't shown us enough to be able to tell you for sure, but a debug session should make it obvious enough.
IanH
Please show the prototype of the C function.
What version of ifort are you running?
damienhocking
Ian, the C prototype is:
MDLPVT_C* BuildPVT_C();
It returns the raw pointer, contained in a C++ unique_ptr kept in a catalog of structs, it hasn't been deleted. We use that catalog all through our software for the .NET and C APIs.
Intel version 2019.5.068, I have 2020 as well.
jimdempseyatthecove
I suggest you use the debugger to assure that the contained pointer within the unique_ptr is returned as opposed to the address of the unique_ptr itself.
Also, have you assured that the specific unique_ptr has not gone out of scope (been dtor'd).
Jim Dempsey
damienhocking
Yeah, the exception is causing the pointer to get wiped, correctly, on a separate thread, so sometimes it's nulled and sometimes it isn't. I don't know why the exception doesn't show up in the IDE though (extra IDE training wheels maybe) but we have another test case now and a couple of bugs to fix.
Steve_Lionel
Debug > Windows > Exception Settings
This lets you tell the debugger to break on various exception types. Otherwise, it will break on unhandled exceptions only.
damienhocking
JohnNichols
Honored Contributor I
Tha mi a ’moladh gun cleachd thu an dì-bhugadair gus dèanamh cinnteach gun tèid am puing a tha taobh a-staigh an uathúil_ptr a thilleadh an àite seòladh an uathúil_ptr fhèin.
I wanted to know if Jim's comment
actually made more sense in Gaelic -- not quite but it is close -- I hate pointers they are a invention of the C gods and ruined Fortran
Steve_Lionel
damienhocking
Unfortunately, it's not. Is the Fortran code as I've written it there correct? If that's OK then I'll dig elsewhere.
Steve_Lionel
It looks OK to me, but as I often say, snippets, excerpts and pseudocode almost always hide the real problem.
damienhocking
And, you would be right. I just found it. There's an exception being thrown from a third-party JSON library that the IDE catches and silently buries, but in console operation propagates up and makes a mess. It's not a Fortran/C interop problem, the code is right. Thank you for the help.
