interoperable funciton resul
amgarching
Dear Participants,
I am not sure where to post bug reports.
I noticed some people do it here.
I started a comp.lang.fortran thread
http://groups.google.com/group/comp.lang.fortran/browse_frm/thread/6297957e666cddc3?hl=en#
and posted a message to comp-fortran-90 about the issues I experienced.
There is at least one opinion from an active compiler developer
(on comp-fortran-90) that this might be a compiler bug.
In short, Intel Fortran compiler versions
11.1 Build 20091130
and
12.1.0.233 Build 20110811
segfault when executing the code below.
Possible reason is insisting on specific compiler calling
conventions for functions with bind(c) attribute.
Alexei
======= main.f90 =========
program prog
use test, only: caller_2
implicit none
call caller_2()
end program prog
======== test.f90 =========
module test
use iso_c_binding
implicit none
private
! Short structs  with size matching that  of some integer  type may be
! passed/returned  in  registers. That  depends  on  the platform  ABI
! convention.   BIND(C)  on  the  type(t)  and  relevant  function
! interfaces requests the Fortran compiler to emulate the behaviour of
! (some) C compiler.
! http://gcc.gnu.org/onlinedocs/gcc/Code-Gen-Options.html
type, public, bind(c) :: t
   private
   integer(c_intptr_t) :: ptr
end type t
type(t) :: a, b
public :: id
public :: caller_2
contains
  function id(i) result(o) bind(c)
    ! id :: type(t) -> type(t), same as jd().
    implicit none
    type(t), intent(in), value :: i
    type(t) :: o
    o = i
  end function id
  subroutine caller_2()
    implicit none
    b = id(a)
  end subroutine caller_2
end module test
This is a fine place for reporting issues. I can see at least one other thing going wrong here - I will look into it further and let you know.
I've identified at least two problems. On Linux IA-32, as you say, the function return value for id is not being put in the register, though the Fortran caller seems to be picking it up from there.
On Windows IA-32, the function id is not picking up the argument from the proper place, but it is returning the value correctly (I think).
Windows x64 seems to be fine. I haven't had the chance to test Linux x64.
Issue ID is DPD200179339. Thanks for bringing this to our attention. I will update this thread with any progress information.
amgarching
Thanks, x86_64 is where I encountered this problem.
I expect this to be fixed in a release later this year.
