29285 Discussions
-ipo and undefined reference to 'MAIN__'
mpv1
Hello, I am a quite novice ifort user. I need to compile my program with -ipo option. It fails with the message:
ifort_8.1.024/lib/for_main.o(.text+0x28): In function `main': undefined reference to `MAIN__'
It only works when I specify -ipo_obj as well. This compiler behaves the same way on the following short program:
program for_main
    integer :: a
    a = 0
end program for_main
Any idea? Thanx, Pavel
Try changing the name of your program from for_main to something else, as I think there is a library routine by that name.
mpv1
Look plz at my output
[]$ ifort -c -ipo test.F90
[]$ ifort -o test test.o
[]$ nm test.o
(nm shows nothing)
And using -ipo_obj
[]$ ifort -c -ipo -ipo_obj test.F90
(no errors)
[pmankevi@nstmklel1 bld]$ nm test.o
                 U for_set_reentrancy
0000000000000000 d LITPACK_0.0.0
0000000000000000 T MAIN__
I understand -ipo doesn't generate .o files the same way the compiler does without -ipo. But fortran user guied doesn't mention that I must specify -ipo_obj along with -ipo flag. Is it correct, or there is some other way of using -ipo without -ipo_obj and above error could be avoided?
Pavel
