29640 Discussions
ipo: error #11018: Cannot open C:\Program Files (x86)\IntelSWTools\mpi\5.1.1.110\intel64\bin
qin__youwei
Hi All,
I am new to parallel programming with Intel visual fortran. I have been trapped by a few days with the compiling issue.
My project includes three files, forlab.f90, stochoptim.f90, and testMain.f90. When compiled separately there is no errors. However, in the process of linking, I got the following errors:
ipo: error #11018: Cannot open C:\Program Files (x86)\IntelSWTools\mpi\5.1.1.110\intel64\bin;
LINK : fatal error LNK1181: cannot open input file 'C:\Program Files (x86)\IntelSWTools\mpi\5.1.1.110\intel64\bin;.obj
I am using VS2015 and parallel_studio_xe_2016.0.041. To enable the MPI, I have add
"C:\Program Files (x86)\IntelSWTools\mpi\5.1.1.110\intel64\include" [with quotes] into Porperties==>Fortran==>General==>Additional Include Directories
"C:\Program Files (x86)\IntelSWTools\mpi\5.1.1.110\intel64\bin" [with quotes] into Porperties==>Linker==>Input==>Dependencies
impi.lib into "C:\Program Files (x86)\IntelSWTools\mpi\5.1.1.110\intel64\bin" [with quotes] into Porperties==>Linker==>General==>Additional Library Directories
Steve_Lionel
Don't do this:
In this property put the library name impi.lib).
And then in Additional Library Directories, put just the path to the folder that contains impi.lib, not including the impi.lib name. I don't know if "C:\Program Files (x86)\IntelSWTools\mpi\5.1.1.110\intel64\bin" is correct for that.
Steve_Lionel
Don't do this:
qin__youwei
thank you, Steve. It solves my problem.
