29285 Discussions
iso-c-binded functions used as procedure-arguments or called as procedure-pointers get wrong argument values
Hans_Peschke
i have some problems with calling some C-functions from Fortran, if they (through an proper interface) are
- referenced through an procedure pointer, or
- procedure arguments.
For details see the code below, or download the tar.gz file in the attachement.
I compiled and debugged it with the latest Intel Fortran Compiler 11.1.072 32-Bit (the problem also occurs with version .069) on an Intel Core 2 Duo Laptop. IDB tells me, that the argument x is not proper transfered to the C function (same for rfun and ifun).
I'm not completely sure, if this code is perfectly conform with the F2003-std and if it is 100% interoperable to C, but the direct call of the C-functions (z=rfun(z) or z=ifun(z)) works, but decide self.
[cpp]#-- ctest.h --#
typedef struct interval { double INF, SUP;} interval ;
#define _PROTOTYPE(function,params) function params
_PROTOTYPE(double rfun, (double x));
_PROTOTYPE(interval ifun, (interval x));
### ctest.h ###[/cpp]
[cpp]#-- ctestr.c --#
#include "ctest.h"
double rfun(double x){
double res;
res = x*x;
return(res);
### ctestr.c ###[/cpp]
[bash]#-- ctesti.c --#
#include "ctest.h"
interval ifun(interval x){
interval res;
res.INF=x.INF*x.INF;
res.SUP=x.SUP*x.SUP;
return(res);
### ctesti.c ###[/bash]
[fortran]#-- ftest.f90 --#
module consts
use, intrinsic :: iso_c_binding
implicit none
public
integer, parameter :: dp = c_double !kind(0.0d0)
type, bind(C) :: interval
real(dp) :: inf, sup
end type
end module consts
module clib
use consts
implicit none
public
abstract interface
function rmap(x) result(res) bind(C)
use consts, only : dp
implicit none
real(dp) :: res
real(dp), value, intent(in) :: x
end function rmap
end interface
abstract interface
function imap(x) result(res) bind(C)
use consts, only : interval
implicit none
type(interval) :: res
type(interval), value, intent(in) :: x
end function imap
end interface
interface fun
function rfun(x) result(res) bind(C)
implicit none
real(dp) :: res
end function rfun
function ifun(x) result(res) bind(C)
implicit none
end function ifun
end interface
end module clib
program cuftest
use consts
use clib
implicit none
call rtest()
call itest()
call rproctest(rfun)
call iproctest(ifun)
contains
subroutine rtest()
real(dp) :: x, y
integer :: i
write(*,*) 'rtest'
x = 1.0_dp
y = 0.0_dp
do i=1,5
x = fun(x)
y = fun(y)
write(*,*) i, 'x=', x
write(*,*) i, 'y=', y
end do
end subroutine rtest
subroutine itest()
type(interval) :: x, y
integer :: i
write(*,*) 'itest'
x = interval(0.0_dp, 1.0_dp)
y = interval(1.0_dp, 1.0_dp)
do i=1,5
x = fun(x)
y = fun(y)
end do
end subroutine itest
subroutine rproctest(f)
real(dp) :: x, y, z
integer :: i
procedure(rmap) :: f
procedure(rmap), pointer :: g
g => rfun
write(*,*) 'rproctest'
x = 2.0_dp
y = 2.0_dp
y = 2.0_dp
do i=1,5
x = f(x)
y = g(y)
z = rfun(z)
write(*,*) i, 'z=', z
end do
end subroutine rproctest
subroutine iproctest(f)
type(interval) :: x, y, z
integer :: i
procedure(imap) :: f
procedure(imap), pointer :: g
g => ifun
write(*,*) 'iproctest'
x = interval(1.0_dp, 2.0_dp)
y = interval(1.0_dp, 2.0_dp)
z = interval(1.0_dp, 2.0_dp)
do i=1,5
x = f(x)
y = g(y)
z = ifun(z)
end do
end subroutine iproctest
end program cuftest
### ftest.f90 ###[/fortran]
Many thanks and Best regards
Hans
I think your source is ok. In proctest, the compiler is ignoring the VALUE attribute specified for the argument in abstract interface rmap. I'll report this to the developers - thanks. Issue ID is DPD200155475.
TimP
In case anyone is curious, I could show the same results on Windows, using gcc .o files linked into the ifort 11.1.065 ia32 compilation.
I reproduced this on Windows easily. I also constructed a Fortran-only sample. Procedure pointers are not required to see this - simply a PROCEDURE declaration that names an abstract interface with VALUE specified for an argument will do the trick. I also found that the compiler is ignoring BIND(C) specified in an abstract interface.
I expect this to be fixed in 12.0 Update 4.
