issue with write from and to the same string
Uwe_H_
After updating from intel fortran 18.0.1 to 19.1.0 I noticed a difference when writing to a character variable. This is a minimum sample:
    program Console1
    implicit none
    character(20) :: line
    line = 'A'
    write(line, '(2(a,x))')line(1:1), 'B'
    write(line, '(2(a,x))')line(1:3), 'C'
    write(line, '(2(a,x))')line(1:5), 'D'
    print *, line
    line = 'A'
    write(line, '(2(a,x))')trim(line), 'B'
    write(line, '(2(a,x))')trim(line), 'C'
    write(line, '(2(a,x))')trim(line), 'D'
    print *, line
    end program Console1
Output with the "old" compiler:
 A B C D
 A B C D
... and with the new one:
       D
 A B C D
I verified this only happens when writing from and to the same variable, not if you use a copy. In the real code I changed it to the trim-approach which makes more sense to me anyway, but I´m still curious: Is this supposed to work like it did before, or is it "forbidden" to use the same variable here?
mecej4
Section 9.6.4.5.1 (note no. 6) of the Fortran 2015 standard says:
If an internal file has been specified, an input/output list item shall not be in the file or associated with the file.
When a program is not standard conforming, the behavior of the program is unpredictable.
FortranFan
That appears to be from the Fortran 2008 standard.  By the way, there's no 2015 standard - there's a 2018 one.
Uwe_H_
Thanks for confirming this.
Btw. it turns out the "trim"-thing also does not work reliably, I guess other than what I expected it does not guarantee to make a copy. So I ended up doing something like
line = trim(line)//'B'
Performance is not an issue in this case.
FortranFan
Uwe H. wrote:
.. Performance is not an issue in this case.
Operations using IO statements such as WRITE to an internal file may not be all that performant anyway.
You may want to consider straightforward "string" operations that help with code readability as well
   character(len=*), parameter :: SPACE = " "
   character(len=:), allocatable :: line
   line = "A"
   line = line // SPACE // "B"
   line = line // SPACE // "C"
   line = line // SPACE // "D"
   print *, line
end
Upon execution,
 A B C D
