29375 Discussions
ivf 11.1 created a program with 4 threads but only using one core, why?
rockycez
I am using ivf 11.1 to parallize my code with openmp. Before the work, I want to try the openmp function first and to investigate whether it works fine on my CPU Q6600. I am surprised to see that the program generate 4 threads indeed. However, when I am checking the usage of the CPU cores, I found only one core is using (25%) (tried few times). Then I turned to my colleague's computer with i7 720q. The program creates 8 threads and also uses one core (13%). I think maybe something setting is wrong. Here is the code:
[fortran]program openmp_test
use omp_lib
implicit none
real*8:: r_double
integer:: i
!$omp parallel do private(i)
do i=1,900000
write(40,*) 'Thread ID',omp_get_thread_num(),'calculated DO no.',i,' = ',dble(i)**3
end do
!$omp end parallel do
end[/fortran]
The program is compiler with the option /Qopenmp.
I want to know which option I have missed resulting the low usage of the multi-core resource.
TimP
You don't leave significant opportunity for parallel work, considering that the write to a single output stream must be serialized implicitly.
I tried it on my Core 2 Duo and saw two threads.
rockycez
How about the usage of your CPU? 50%?
rockycez
Do you mean that if I replace the I/O code with some function/subroutine doing 'real' work, the usage of CPU will increase?
Yes, if you actually do computational work in the loop, you should see more cores active. As Tim says, all you have is a WRITE to a common unit, so that gets serialized. But if you look at the output, you'll see different thread numbers indicating that they are indeed running in separate threads.
