29641 Discussions
Create a new directory using Fortran 90
apostok
Hallo,
I want to create a new directory in a specific location in the hard disc using Fortran 90.Could you please help me with this issue?
Les_Neilson
Valued Contributor II
Since you posted here the I assume you are using the Intel Fortran compiler. See the makedirqq entry in the help.
use ifport
logical result
character(some_suitable_length) path
path = 'c:\path\to\wherever\you\need'
result=makedirqq(path)
(Note, as the help states, only one directory at a time can be created so in example above everything before "need" has to already exist)
Les
Les_Neilson
use ifport
logical result
Les
apostok
It works. Thank you very much for your assistance.
