ivf 2017 seems to hose fonts
Brooks_Van_Horn
 have been working on a statistical program for the last 18 months using IVF integration with Visual Studio Community. I've compiled with 2015 then 2016 and now 2017. But with 2017 I get all my fonts reduced. Fontsize = 24 displays as 8 and others reduced proportionally. Everything was AOK until I installed 2017 and wow!
A small piece of my code is:
         hDC = GetDC(NULL)
         if (hDC == NULL) Then
            mas = 16
            hDC = GetDC(NULL)
         End If
         sxWidth  = GetDeviceCaps(hDC, HORZRES)
         syHeight = GetDeviceCaps(hDC, VERTRES)
         sColorDepth = GetDeviceCaps(hdc, BITSPIXEL) *  &
                       GetDeviceCaps(hdc, PLANES)
         iret = ReleaseDC(NULL,hDC)
         if (sxWidth < 1024) Then
            mas = 12
            DOT1 = 1
            DOT2 = 1
            DOT3 = 2
         elseif (sxWidth < 1600) Then
            mas = 14
            DOT1 = 1
            DOT2 = 2
            DOT3 = 2
         else
            mas = 16
            DOT1 = 1
            DOT2 = 2
            DOT3 = 3
         end if
         bret = GetClientRect(ghDlg, rectd)
         bret = GetClientRect(ghWndMain, rectp)
         rectd%bottom = rectp%bottom
         rectp%left = DIALOGWIDTH + 1
         rectd%right = DIALOGWIDTH
         gMaxx = rectp%right - rectp%left
         gMaxy = rectp%bottom - 1
         bret = SetWindowPos(ghDlg, int(NULL,HANDLE), 0, 0, DIALOGWIDTH, DIALOGHEIGHT, 0)
         bret = DlgSetInt(gDlg, IDC_MYSPIN, 0, DLG_POSITION)
         ghBrushWhite = CreateSolidBrush (RGB(248,248,255))
         ghBrushBlack = GetStockObject(BLACK_BRUSH)
         ghPen = GetStockObject(BLACK_PEN)
         hBlackPen = ghPen
         ghBrush = ghBrushWhite
         lp%fErase = 0
         lp%rcPaint = rectp
!  Fill-in the log paint structure
         lf%lfWidth = 0
         lf%lfEscapement = 0
         lf%lfOrientation = 0
         lf%lfWeight = FW_BOLD
         lf%lfItalic = FALSE
         lf%lfUnderline = FALSE
         lf%lfStrikeOut = FALSE
         lf%lfCharSet = ANSI_CHARSET
         lf%lfOutPrecision = OUT_DEFAULT_PRECIS
         lf%lfClipPrecision = CLIP_DEFAULT_PRECIS
         lf%lfQuality = DEFAULT_QUALITY
         lf%lfPitchandFamily = ior(DEFAULT_PITCH, FF_DONTCARE)
         lf%lfFaceName = "Courier New"C
         If (hMyFont12 == NULL) Then
            lf%lfHeight = mas
            hMyFont12 = CreateFontIndirect ( lf )
            lf%lfHeight = mas + 2
            hMyFont16 = CreateFontIndirect ( lf )
            lf%lfHeight = mas + 4
            hMyFont20 = CreateFontIndirect ( lf )
            lf%lfHeight = mas + 8
            hMyFont24 = CreateFontIndirect ( lf )
            lf%lfHeight = mas + 16
            hMyFont36 = CreateFontIndirect ( lf )
         end if
Any suggestions would be greatly appreciated/
Brooks
Paul_Curtis
Valued Contributor I
The background color setting function has been renamed in IVF (carried over from MS Fortran) to avoid a conflict.
rval = MSFWIN$SetBkColor (hdc, yellow)
Also, the background/foreground color is simply an attribute of the DC for text output, it is not the same thing as selecting a brush which uses/creates an allocated resource and hence must be destroyed/deallocated/restored when that code section completes; so the color value is not a handle to anything and the extra calls to "restore" the "oldbkcolor" and so forth are not needed.
There are a number of WinAPIs which have been similarly renamed; do a search on MSFWIN$ over the IVF project include paths.
Yuan_C_Intel
Hi, Brooks
The GetDC, GetDeviceCaps are all Windows APIs. Besides upgrade intel Fortran to 2017, have you also upgraded Visual Studio Community or your Windows operating system?
Yuan_C_Intel
Hi, Brooks
In addition, did you try debug build? Will you see the same issue with optimization disabled?
JVanB
Valued Contributor II
Have you tried messing around with SetProcessDpiAwareness to see whether that might be the problem?
andrew_4619
Firstly it seems strange that changing compiler level would cause this problem. Do you still have the older compilers in VS? Options > intel compilers > fortran - or something like that - can be used to select an older compiler for back to back testing.
The font selections is a windows best guess to match the attributes you have selected, changes in windows/windows environment  could effect that.
I have no magic insight into this problem, I would be tempted after selecting the font object from the handle to call
GetTextMetrics for the working and non-working version just to verify exactly what is happening.
Paul_Curtis
This is a Windows issue, only accidentally related to IVF.  I don't think you should rely on all the elements of your logfont structure remaining constant over multiple calls/returns to CreateFontIndirect().  I have put similar code in a subroutine which can be called multiple times for multiple fonts...
! Creates a font with simple characteristics. The face name and size
! are provided, along with bold and italic flags. Returns a handle
! to the new font, or 0 on failiure.
INTEGER(HANDLE) FUNCTION CreateSimpleFont (faceName, size, bold, italic)
    IMPLICIT NONE
    CHARACTER(LEN=*), INTENT(IN)   :: faceName
    INTEGER, INTENT(IN)            :: size
    LOGICAL, INTENT(IN)            :: bold
    LOGICAL, INTENT(IN)            :: italic
    TYPE(T_LOGFONT)                :: logfont
    INTEGER(HANDLE)                :: hfont
    logfont%lfHeight		= size
    logfont%lfWidth			= 0
    logfont%lfEscapement	= 0
    logfont%lfOrientation	= 0
    IF (bold) THEN
        logfont%lfWeight = FW_BOLD
    ELSE
        logfont%lfWeight = FW_NORMAL
    END IF
    logfont%lfItalic			= italic
    logfont%lfUnderline			= .FALSE.
    logfont%lfStrikeout			= .FALSE.
    logfont%lfCharSet			= ANSI_CHARSET
    logfont%lfOutPrecision		= OUT_DEFAULT_PRECIS
    logfont%lfClipPrecision		= CLIP_DEFAULT_PRECIS
    logfont%lfQuality			= DEFAULT_QUALITY
    logfont%lfPitchAndFamily	= IOR(DEFAULT_PITCH, FF_DONTCARE)
	logfont%lfFaceName			= faceName
    hfont = CreateFontIndirect (logfont)
    CreateSimpleFont = hfont
END FUNCTION CreateSimpleFont
Brooks_Van_Horn
Hi  Paul,
I'll try it but what 'use' statements do I need?
Brooks
Robert_van_Amerongen
New Contributor III
You can use the module IFWIN
Robert
Paul_Curtis
The F90 interface to CreateFontIndirect() is in GDI32.f90, which is included in IFWIN.f90.  You will also need IFWINTY.f90 for Windows defines such as HANDLE, T_LOGFONT, FW_* and so forth.  Siince your existing code already references those items, no changes may be required, just put the subroutine in the same module as your calling code.
Brooks_Van_Horn
OK, got it to work but the textout function is now printing my font with a white background. I added SetBkColor and it compiles OK but I get a error LNK2019: unresolved external symbol _setbkcolor referenced in function MMYHEADEROUT_mp_MYHEADEROUT in the link process. What must I do to the project options to resolve this error. I am running a pure x64 compile/link setup.
Here is my revised code modified from above
!DEC$ ATTRIBUTES STDCALL, ALIAS : 'CreateSimpleFont' :: CreateSimpleFont
    use IFWIN
    Integer(Handle):: CreateSimpleFont
    INTEGER(4), INTENT(IN)         :: size
    LOGICAL(4), INTENT(IN)         :: bold
    LOGICAL(4), INTENT(IN)         :: italic
    logfont%lfWidth			= 0
    IF (bold) THEN
    ELSE
    END IF
    return
and I invoke it with
            hMyFont12 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
            mas = mas + 2
            hMyFont16 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
            mas = mas + 4
            hMyFont20 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
            mas = mas + 8
            hMyFont24 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
            mas = mas + 10
            hMyFont36 = CreateSimpleFont( "Courier New"C, mas, .TRUE., .FALSE.)
         end if
The code using the font is
    use ifwin
    use gdi32
    use user32
    use ifqwin
    use kernel32
    use PearsonGlobals
Integer(4)::     x, y, lnth, lenx
Integer(BOOL)::  bret
Integer(4):: oldBkColor
Integer(4):: BlueBkColor
Character(100):: myBuffer
Type (T_TEXTMETRIC)    ta
 if ((hmyFont36 == NULL) .or. ($Maxi == FALSE)) Then
         return
      End if
      if (ghwDC /= NULL) Then
         bret = EndPaint(NULL, lps)
      End If
      ghwDC = GetDC(NULL)
      if (ghwDC == NULL) Then
         return
      End If
      hOldPen = SelectObject(ghwDC, GetStockObject(BLACK_PEN))
      BlueBkColor = RGB(0,0,255)
      oldBkColor = SetBkColor(BlueBkColor)
      hOldFont = SelectObject(ghwDC, hMyFont24)
      myBuffer = 'Pearson Distribution Curves (PDC)'
      myBuffer = TRIM(AdjustL(myBuffer))
      bret = GetTextMetrics(ghwDC, ta)
      Call GetLength(myBuffer,lnth)
      lenx = ta%tmAveCharWidth * lnth / 2
      x = GetDeviceCaps(ghwDC, HORZRES) / 2 - lenx
      y = 0
      bret = textOut(ghwDC, x, y, myBuffer, lnth)
      rectg%top = 0
      rectg%bottom = 80
      rectg%left = 700
      rectg%right = 1200
      bret = ValidateRect(NULL, rectg)
      hOldFont = SelectObject(ghwDC, hOldFont)
      hOldPen = SelectObject(ghwDC, hOldPen)
      oldBkColor = SetBKColor (oldBkColor)
      x = ReleaseDC(NULL, ghwDC)
      ghwDC = NULL
      return
Using this code I am actually writing in the system area, which on my Win10 maxhine is a blue band.
Brooks
andrew_4619
There is a function setbkcolor in IFQWIN and and SDK function of the same name in GDI32 that has a different interface (it takes 2 parameters) I think that is the one you are after.
andrew_4619
At a glance I don't see any need for USE IFQWIN in that routine. Also you don't need GDI32, USER32 or KERNEL32 as they are all included in IFWIN.
Paul_Curtis
Brooks_Van_Horn
Thanks Andrew and Paul.
Brooks
