ivf11.1.072/73 + openmp
yeg001
Hi, every one. Iencountered a defect when i used ivf11.1.072/73for linux. And my firend tested it ina someedition ofivf for windows. And he also find it.
I compile the file like this,
ifort 1dshggl.for -openmp
and the outputarrayew1 is differntfrom ew2.
with out "-openmp", or other versions of ivf, such as 11.1.038, it is fine.
pbkenned1
This has been reported to compiler engineering as defect #DPD200161914. I'll pass along updates I receive from the developers. The bug exists in Linux compiler 11.1.069 or later, and is present in v12.0 as well. The last known good Linux compiler is 11.1.064.
Patrick
pbkenned1
It appears to be an -O2 or higher optimisation bug. I see correct results at -O0/-O1. Let me investigate, and I'll get back to you.
Patrick Kennedy
Intel Developer Support
yeg001
Thank you for your reply. I had tried to simplify the code, but failed. I hope it can help intel to improve openmp and fix the defect in next update.
pbkenned1
Patrick
yeg001
Thank you for your help, Patrick.
pbkenned1
This issueshould be fixed in Intel Fortran Compiler XE Update #2 (the V12.0 compiler),which we plan to release shortly. I'll update this thread with the package identifiers once the packages are posted in the download center.
Patrick Kennedy
pbkenned1
This issue is resolved in ifort XE update #2. The packages containing the fixes are:
l_fcompxe_2011.2.137 (Linux*)
m_fcompxe_2011.2.142 (Mac OS X*)
w_fcompxe_2011.2.154 (Windows*)
Patrick Kennedy
