29277 Discussions
keeping ifort 17.1 with 19.1 install
Scott_L_
I would like to install ifort 19.1 to use with MS visual studio 2019.   The warning I get is that ifort 17 will be uninstalled if I proceed.    It is critical to retain VS 2015 with ifort 17.1 for production use while I test VS 2019 and ifort 19.1 as a potential upgrade.    Is there a way I can retain VS 2015/ifort 17.1 but install VS2019 with ifort 19.1?
Intel® Visual Fortran Compiler 17.0 Integration(s) in Microsoft Visual Studio* is already installed.
If you proceed to install, the Intel Visual Fortran Compiler 17.0 IDE integration(s) will be uninstalled and the Intel(R) Parallel Studio XE 2020 Cluster Edition for Windows* IDE integration will be installed. You will no longer be able to select 17.0 or older Intel Visual Fortran Compilers from the Visual Studio IDE (if it is currently installed).
Thanks, I have a short window where I have permission to install anything.
thanks,
scott
Steve_Lionel
That's not what it says. Only one compiler's version of the Visual Studio integration can be present in a specific version of VS at a time. The new integration has some support for older compiler versions, but only those that supported the specific VS version. The 17 compiler never supported VS2019, so this doesn't matter.
For information on how to keep multiple VS versions going and use different compilers, see https://software.intel.com/en-us/articles/using-older-intel-visual-fortran-versions-in-different-microsoft-visual-studio-versions
Scott_L_
Thank you. Can I just get confirmation that installing ifort 19.1 will integrate with VS 2019 but will not uninstall ifort 17.1 from VS 2015? I really cannot afford to lose ifort 17.1 integrated with VS 2015 as that is our production base for the rest of this year. Any advice would be GREATLY appreciated. The warning form the 19.1 installer does specify which version of VS will have ifort 17.1 removed from it.
Steve_Lionel
It should not uninstall ifort 17 from VS2015, but if you are concerned with that, follow the instructions towards the bottom of the article I linked above.
