latest DFORRT.DLL version?
philbrierley
I distribute an application that includes a fortran dll. I hav a client that had problems with the dll. When I checked the install log I discovered that DFFORT.DLL was not being installed as a newer version was already detected in the windows/system32 directory.
The version I am trying to install is 6.6.893.101
My question is, is there a newer version I should be using (I've not had feedback yet on the version that already exists) and why won't my dll work with whatever version is currently on the pc. I am suspecting it is actually an older version whichmay explainwhy my dll won't work. If Ioverwrite the existing file willwhatever application put it there still work?
If I install DFFORT.DLLand my DLL in the same folder as the application executable (which works),but there is also another version of DFFORT.DLL in wins/system32,do you know which one it will use?
Also given that CVF is now defunct, what is the last version ever of this DLL?
Phil
philbrierley
forgot to mention I am using compaq visual fortran not intel visual fortran
Windows looks for DLLs using the following order:
Current directory
Directory containing the executable
PATH
Windows
WindowsSystem
The latest DFORRT.DLL would have been provided with the CVF 6.6C update.
