29273 Discussions
idb - help to understand what is going on?
emmendes
Hello
I confess that I am a newbie as far as idb goes but since I cannot find my mistake and wonder whether someone out there could shed some light.
My program works for several different scenarios, but there is one that a segmentation fault comes out.
idb Trispec_sim
Intel Debugger for IA-32 -based Applications, Version 9.0-16, Build 20051121
object file name: Trispec_sim
Reading symbolic information from /home/eduardo/Hinich_2006/code_Trispec_sim/Trispec_sim...WARNING: unable to determine length of string variable.
done
(idb) run
Trispec is assuming trispec.cnl, trispec.out
and trispec.mat with no data written to the mat file
Here 0
50000 500 2806131 1075270 1 250
250 0 3
Thread received signal SEGV
Info: Optimized variables show as when no location is allocated.
stopped at [subroutine p234(real*4 (:), real*8 (:), complex*16 (:), real*8 (:), real*4 (:), real*4 (:), real*8 (:), real*8(:), integer*4, integer*4, integer*4, integer*4, integer*4, integer*4, integer*4, integer*4, integer*4):1175:7 0x08057d70]
1175 write(6,*)'Here 0a'
1175 is the firstline on p234. I have checked the variables and sizes carefully. There is nothing wrong as far as I can see. 2806131 and 1075270 are the length of some real*4 and real*8 arrays. Could this be the problem?
Many thanks
Ed
emmendes
Solved!
