29261 Discussions
ld: library not found for -lgcc_s
donald-s-dunbar
I am trying to useintel64/ifort (vs. 11.0) to compile Fortran code under Mac Os 10.5.8. For any attempted compile and link I get the message:
"ld: library not found for -lgcc_s."
There is no C code involved so I'm not sure why gcc pops up. I've made certain to run "ifortvars.csh intel64" before the compile and the error occurs whether or not the options include "-L/usr/lib -lgcc." I've had no issues like this using the 32 bit compiler but would now like to try using the 64 bit compiler.
Any suggestions?
- Don
Ron_Green
Quoting - donald-s-dunbar
Any suggestions?
- Don
Which Xcode version do you have? And when you go to the Apple menu, About This Mac, you do have a "Core 2 Duo" and not an older "Core Duo", correct?
donald-s-dunbar
I'm not using Xcode; I'm compiling the old-fashioned way - using make. I get the same error on both a "Core Duo" (a laptop) and a "2 x 3.2 GHz Quad-core Intel Xeon" (a Mac Pro).
Ron_Green
I see I didn't explain myself well. The Intel Fortran Compiler for Mac OS X requires a compatible Xcode installation. This is because we use the linker and libraries that are included in Xcode in order to maintain compatibility.
The list of supported Xcode versions for your version of the compiler is listed in the ReleaseNotes document, /opt/intel/Compiler/11.0/0xx/Documentation/ ... etc. You MUST have a compatible Xcode installed. With 11.0 these may be older Xcode versions - it may not work with newer ones so carefully check the ReleaseNotes documentation for the necessary versions of Xcode.
This is why I asked for your Xcode version, not because I assumed you were using Xcode over the command line.
ron
donald-s-dunbar
ron
I see. My Xcode version is 3.1.1 which is listed under system requirements in ReleaseNotes.pdf for the compiler I'm using: vs. 11.0 (Build 059)
Ron_Green
OK, I'm building up a sandbox with this Mac OS X, Xcode and compiler combo. It might take me several hours to get everything installed.
ron
Ron_Green
ron
I can't reproduce what you are seeing. Here is the output on my older Core Duo 32bit system with 10.5.8 and Xcode 3.1.1, Ifort 11.0.059
source /opt/intel/Compiler/11.0/059/bin/ifortvars.sh ia32
ifort -o hello hello.f90
file hello
hello: Mach-O executable i386
./hello
hello
source /opt/intel/Compiler/11.0/059/bin/ifortvars.sh intel64
file hello
hello: Mach-O executable x86_64
./hello
bash: ./hello: Bad CPU type in executable
the above is expected on a 32bit OS and 32bit processor.
Now, I did install Xcode in the default location, /Developer. We have in the past had issues with non-default installation directories. Is your Xcode in /Developer OR can you symbolically link it to /Developer?
Another thing that might help is if you can show your Makefile. And you invoke the makefile directly, right? In other words, you are not using 'sudo' in any way shape or form.
ron
