libirc.a compiling error
jipazimp_mx
I'm using intel 11.1 compilers at linux ubuntu 10.04, kernel 2.6 system, and i've tried to compile the mfix program, everything runs ok, but at the end of the compiling process I got the following message:
______________________________________________________________________________________
ld: mfix.exe: hidden symbol `__intel_cpu_indicator_init' in /opt/intel/Compiler/11.1/073/lib/ia32/libirc.a(cpu_dis.o) is referenced by DSO
ld: final link failed: Nonrepresentative section on output
make: ***[mfix.exe] Error 1
***File mfix.exe NOT created
_______________________________________________________________________________________
It seems that is something wrong with libirc.a library.
Any help is very welcome
jean_pinho
Steve,
I Will try it.
