At NAG we build libraries with ifort, and redistribute libmmd.dll with our libraries. Our users sometimes complain that they have other copies of libmmd.dll on their systems, which are incompatible with the ones we distribute. This can break their applications which depend on NAG libraries, or break their other applications, depending on how their PATH environment variable is set up. Naturally they then complain to us about it.
I think that the recommended solution is to copy libmmd.dll into the same directory as the executable that needs it. The problem with this is that if you have many applications all depending on the NAG Library, you can end up with many copies of libmmd.dll lying around all over your system. Certainly our users don't like the idea - they would prefer one copy of this library (and other run-time libraries).
I would like to suggest that run-time libraries like libmmd.dll should have version numbers attached, which could be upgraded when the contents become incompatible. I guess that for our purposes we could avoid this problem by renaming the dll to something else, and using an object file editor to hack the internal name of the library to match. I doubt very much though that the Intel compiler team would approve of this idea.
Does anyone know of any other good way around the problem?
Mick Pont
Numerical Algorithms Group, Oxford
They seem to contain similar symbols.
Arjen
An alternative to putting copies next toeach copyt of the NAG library could be to use a similar
scheme as is done for the MSVC runtime libraries: use a manifest file to find the right version.
(Luckily I do not know the details of how you should achieve that - I have been confronted with
problems regardingmanifest files on more than one occasion and although I think we have been
able to solve them each time they arose, it was a nightmare, especially if the client was not
allowed toinstall these DLLsthe recommended way. Just understanding what they are all about
requires either thorough study of the arcane documentation that is scattered over the Internet
or smoking funnycigarettes ... and I do not smoke - sorry, this is frustration seeking a way out)
Arjen
I suppose it would be difficult to examine the customer's situation during installation and avoid adding an old .dll when a more up to date version is present, or warn about the presence of an older .dll while adding the new one.
