29277 Discussions
libstdc++.so.5: no version information available on EM64T
s_breedveld
I have installed Fortran 9.0 for Linux on an EM64T system. The compiler seems to work fine, but for every source compiled, the system warns about:
$ ifort helloworld.f
/opt/intel/fortran90/bin/fortcom: /usr/lib/gcc-lib/x86_64-pc-linux-gnu/3.3.5/32/libstdc++.so.5: no version information available (required by /opt/intel/fortran90/bin/fortcom)
The compiled program runs fine without problems. It is just that these warnings make it difficult to intercept warnings.
My system uses gcc-4.1 by default, but as you can see above I also installed gcc-3.3.5 for the 32bit libstdc++ compatability library.
ldd shows:
$ ldd /opt/intel/fortran90/bin/fortcom
linux-gate.so.1 => (0xffffe000)
libm.so.6 => /lib32/libm.so.6 (0xf7f38000)
libstdc++.so.5 => /usr/lib/gcc-lib/x86_64-pc-linux-gnu/3.3.5/32/libstdc++.so.5 (0xf7e7f000)
libgcc_s.so.1 => /lib32/libgcc_s.so.1 (0xf7e75000)
libc.so.6 => /lib32/libc.so.6 (0xf7d5e000)
/lib/ld-linux.so.2 (0xf7f72000)
From what I read is that warnings about libstdc++.so.5 are customary when libstdc++.so.5 is compiled with a different gcc version than the binary (fortcom).
So what gcc version should I compile libstdc++ with?
Or am I missing something else? Yes, linux-gate.so.1. How to fix this?
Thanks in advance,
s_breedveld
Ok, replying on your on post is bad, but I will do it anyway.
With ldd -v I found out that:
Version information:
libstdc++.so.5 (CXXABI_1.2) => not found
libstdc++.so.5 (GLIBCPP_3.2) => not found
So I guess I *should* compile gcc-3.2? Anyway, gcc-3.2 won't even compile anymore.
It turned out that the libstdc++.so.5 linked to is not the correct one. Chaning the priority of the x86-compat-emul libraries in /etc/ld.so.conf or uninstalling gcc-3.3.5 works.
Only linux-gate.so.1 still cannot be found, but this is the same on my x86 systems and does not seem to cause any problems.
TimP
Normally, you would have the same version of gcc active with both 32-bit and 64-bit g++ compilers. 'g++ -m32 -print-search-dirs' would show the paths to search for 32-bit libraries, including libstdc++.
From what you have said, I'm guessing you have done something different.
If you upgrade to ifort 9.1, you should be able to run with gcc-4.1, provided that you have installed both 32- and 64-bit g++ support.
