29389 Discussions
linker error with Xcode 15 and ifort oneapi 2023
sri3
I have a Fortran function that uses ** operation, the linker gives the following error
ld: Undefined symbols:
___powr8i8, referenced from:
_pow_ in pow.o
clang: error: linker command failed with exit code 1 (use -v to see invocation)
The libraries specified to the linker are  -lifcore -limf -lintlc -lirc -lsvml  apart from others.
I am using OneAPI 2023 The clang linker is use since, I have link against other c libraries.  Is there a way to fix this linker error ?
Ron_Green
Check your paths - powr8i8 is in libimf, which you are correctly trying to link in with -limf
