29275 Discussions
linking Problems: /opt/intel/fc/9.0/lib/for_main.o(.text+0x0):./src/libfor/for_main.c ...
lliechte
I have a problem linking a mixed c/fortran code:
Here is the error message:
ifort -oBin/field.exe Objects/menu_transformations.o Objects/menu_visualizations.o Objects/dummy_hdf.o Objects/u_functions.o Objects/u_menu.o Objects/u_menu_main.o Objects/diff_op_w2d.lib.o Objects/init_w2dlap_filt.o Objects/init_w2drec_filt.o Objects/simulations_w2d.lib.o Objects/init_w1dint_filt.o Objects/init_w2dpois_filt.o Objects/mask.lib.o Objects/w_t_adapt_2dw.lib.o Objects/fftw3.o Objects/main.o Objects/field.o Objects/gnuplot.o Objects/palette.o Objects/ppm.o Objects/dx.o Objects/input_bin.o Objects/input_output.o Objects/slave.o -lfftw3 -LSources/Field_includes/fftw/lib/ -lm
Objects/main.o(.text+0x0): In function `main':
main.c: multiple definition of `main'
/opt/intel/fc/9.0/lib/for_main.o(.text+0x0):./src/libfor/for_main.c: first defined here
ld: Warning: size of symbol `main' changed from 76 in /opt/intel/fc/9.0/lib/for_main.o to 47 in Objects/main.o
/opt/intel/fc/9.0/lib/for_main.o(.text+0x39): In function `main':
./src/libfor/for_main.c: undefined reference to `MAIN__'
gmake: *** [Bin/field.exe] Error 1
The file Objects/main.o is created with gcc:
gcc -c -IInclude -oObjects/main.o Sources/main.c
No error messages or warnings here.
Thank you for help.
Luke
Add to the ifort command -nofor_main
lliechte
Thanks, it works.
brunno_goldstein
Steve, i had the same problem but my Program is in Fortran code only. I'm using eclipse 3.4 with intel fortran compiler professional edition v.11 .
Any Idea?
output :
Building target: NewSar2009
Invoking: Intel Fortran Linker
ifort -o"NewSar2009" ./EasyTools.o ./LinuxShell.o ./Main.o ./Sarinv/calccut.o ./Sarinv/calibra.o ./Sarinv/cfftb.o ./Sarinv/cfftf.o ./Sarinv/cffti.o ./Sarinv/chasar.o ./Sarinv/costp.o ./Sarinv/fft.o ./Sarinv/forward.o ./Sarinv/fttok.o ./Sarinv/gen_para.o ./Sarinv/grid_para.o ./Sarinv/grid_setup.o ./Sarinv/iecf_len.o ./Sarinv/imaging_para.o ./Sarinv/interfaces.o ./Sarinv/invert.o ./Sarinv/isoplot.o ./Sarinv/julian.o ./Sarinv/neg_cmplx.o ./Sarinv/neg_real.o ./Sarinv/newspec.o ./Sarinv/rdcollidx.o ./Sarinv/rdgenpar.o ./Sarinv/rdindpar.o ./Sarinv/rdsardate_ers1.o ./Sarinv/rdsarspec_ers1.o ./Sarinv/readwsp.o ./Sarinv/relmax.o ./Sarinv/sarinv.o ./Sarinv/select.o ./Sarinv/stepinfo.o ./Sarinv/uwafilter.o ./Sarinv/variance.o ./Sarinv/waven.o ./Sarinv/wrcollidx.o ./Sarinv/wrires.o ./Sarinv/wtail.o ./Partinv/correl.o ./Partinv/crossas2.o ./Partinv/leastsquare.o ./Partinv/partout2.o ./Partinv/pythag.o ./Partinv/svdcmp.o ./Partinv/swellsep.o ./Partinv/tustre2_wkst.o ./Findbest/findbest.o
ld: /lib/for_main.o: No such file: No such file or directory
make: ** [NewSar2009] Erro 1
make: O alvo `all' no foi reprocessado por causa de erros.
Thank you!
Ron_Green
Any Idea?
output :
Thank you!
Steve is out at the Intel Developer Forum (IDF) in San Francisco this week, so I'll take a stab at this.
My guess is that Eclipse is not searching the library path to the Intel Fortran compiler libraries. Prior to starting Eclipse, do you 'source /opt/intel/.... ifortvars.sh' - perhaps put that into your .bashrc file to make sure LD_LIBRARY_PATH includes the Intel library path. Now if you are doing this, perhaps eclipse is ignoring LD_LIBRARY_PATH. Is there some linker setting that allows you to specify additional library paths? If so, add the path to the /lib directory for your compiler.
ron
brunno_goldstein
ron
Thanks for fast help Ronald.
I did the command 'source /opt/intel...ifortvars.sh intel64' after the installation but i'm not sure that i put it in my .bashrc file. I need to edit it and add what exectaly?
Sorry for my reckless and poor information. =/
Brunno
brunno_goldstein
Brunno
Ronald, seems like the problem is with eclipse. I add the LD_LIBRARY_PATH to the .bashrc file and now i can compile the program via command line but with eclipse it's the same problem. I'm going to try the second thing you said...
Thanks for all!
brunno_goldstein
Thanks for all!
To solve the problem with eclipse and lib do this in eclipse:
Go to Run As -> Environment -> New
Then put,
Value: "your lib path":$LD_LIBRARY_PATH
In my case was:
Value: /opt/intel/Compiler/11.1/046/lib/intel64:$LD_LIBRARY_PATH
Thanks again Ronald!
