linking to .dll using .lib
David_Mccabe
I am attempting to link an Intel Fortranprogram to aC++.dll using the following method
project properties:
-Configuration Properties
-Linker
-Input
Additional Dependancies =
My problem is that the .lib file is not located in the same folder as the .dll.
Is it possible to link to this .dll without moving either of the files and what additional steps would I have to take?
mecej4
The Microsoft linker does not use the DLL. Therefore, only the .LIB file needs to be in a known location.
After linking, in order to run your .EXE you need to have the DLL accessible through the PATH variable or through a setting in your project.
